stupid question with rear stb's
can you put a rear strut tower brace with a system in the trunk??? i might sound stupid but i have aways wondered about it????
You're severely limited with what will fit, Robert. Would have to work the design around the STB.
I've got a 10" JL in mine... nothing fancy from presentation /show standpoint. I could put two 10's in a similar configuration and still keep the STB. I don't recall seeing any extensive trunk setups in GS's that have kept the STB, assume they'll post here if they do. Here's a picture of mine: http://www.somniplex.com/gallery/alb...3/res15856.jpg |
thanks dave any others???????
It can be done and cusco is another company that makes one.But as for the system, you would have to work around it.To make a box around the bar really isn't that big of a deal.It would only require some more angles cut into the box design.
Originally posted by loonyrobert3 thanks dave any others??????? |
every system is different and custom, so yes you can make it fit but also yes it would be very limited
thank you all for the input!!!!
