Accelerator Position Sensor Issue (Throttle lag)
I have the standard throttle lag issue that apparently plagues numerous Lexus models. My 02 has just under 35k, no codes have popped up, and all of the other items seem fine (TPS/TB motor) so i think its the degradation of the soldered connections in the APS.
anyone else have this issue? I see on some other models that the owners removed the APS, cut open and resoldered the contacts with great success, anyone on here do the same with the SC430?
Im searching for the replacement part but haven't found the number as of yet.
Im mechanically inclined so if the resolder is an option id be up to trying that.
any input is appreciated. TIA
2wPushkins (09-14-19)
Post #7 is the answer...
https://www.clublexus.com/forums/sc4...ottle-lag.html
Leave ECT Power on, down shift to 3 or 4 and floor it. That's how I change lane in traffic.
I experience the same thing, especially when I merge into traffic, and it's like wth?
Have you try the trans pressure mod? That's next on my list when next time I change my trans fluid. Hope it helps.
I've heard that change to the Supra 3.76 LSD diff works. https://www.clublexus.com/forums/sc4...diy-sc430.html However, this is way beyond what I'm willing to do.
That's how a Toyota transmission works.
I’ve experienced this and it is the traction control...happens to me when I take off fast and wheels break loose...on a turn.
I just know I have experienced this issue after making a quick turn, or u turn and WOT, only to have the car lag on take off...if I do it from standstill or straight line, never
You are stopped at a light; The light turns green, you press the pedal and there is a pause. It's weird. The engine is solidly running, but your mind wonders if the engine died on you.
No, what he is talking about is different. It just sort of pops up one day, with far different symptoms you are talking about. It started happening on my car a couple of days ago.
You are stopped at a light; The light turns green, you press the pedal and there is a pause. It's weird. The engine is solidly running, but your mind wonders if the engine died on you. Then it engages in normal fashion. So your power curve is normal, just with a delay in the front.
I noticed the lag, but didn't notice slower acceleration. But maybe it was there. I think I will amend my original post
