NX - 1st Gen (2015-2021)
brake sound in reverse
Old 07-20-19, 11:12 AM
matmelt
matmelt's Avatar
Default brake sound in reverse
I recently acquired a 2016 nx200t CPO with less than 15k on the ODO.
I noticed when I reverse and engage my break pedal and release I can hear the brakes make noise but its for a second - the sound sounds like connection and release. It doesnt vibrate it just sounds like the breaks making contact and then releasing.
Any idea what this could be?
VIDEO LINKS BELOW !
Old 07-20-19, 12:17 PM
Lex2000TL
Lex2000TL's Avatar
This is typical Toyota brake clunking sound. Nothing to worry about.
Old 07-20-19, 12:49 PM
slypx
slypx's Avatar
Or the electric parking break motor disengaging if you use auto-mode
Old 07-20-19, 07:58 PM
matmelt
matmelt's Avatar
thank you for your response ! eases my mind a bit !
Old 07-20-19, 07:59 PM
matmelt
matmelt's Avatar
well it happens consistently when im in reverse. i can be in reverse go 2 feet brake (get noise) go 2 feet break (get noise) but it doesnt happen moving forward.
Old 07-21-19, 07:22 AM
ukrkoz
ukrkoz's Avatar
Normally, there is faint click when reversing. Reason being, brake pads are set on spring steel shims, between pad and brake bracket. Those do compress some when rotor rotation direction changes. Thjis been happening on Toyotas and Hondas for years and years. Without any problem.
But it should happen ONCE and done, not constantly clicking every time you step on brake pedal reversing.
Also, brake pads developed directional wear pattern. Hence, when you reverse, pads grab rotor "against the hair", producing sound. This is most noticeable for vehicles parked outsaide, as rotors build up some rust overnight. That noise is different from the previously described one - it's rub vs click.
eBrake should disengage the very moment you let go of the brake pedal and not produce any noises again.
Old 07-21-19, 01:27 PM
matmelt
matmelt's Avatar
Thank you again for the responses guys - here is a link to the sound I recorded a video.
REAR BRAKES ONLY
FRONT TO REAR
Robb79 (02-24-22)
Old 07-22-19, 06:59 AM
ukrkoz
ukrkoz's Avatar
Personally, I'd remove wheels and inspect brakes. It does sound like pads direction reset click. I bet, it's more faint inside, dampened by the vehicle. But it is there and surely is heck of annoying.
Considering it's under warranty, take it to dealer and let them have it. They are likely to tell you that it's normal, just like I said. Yep, but for SINGLE click, not consecutive ones. Looks like pads rebound back and reset every time you release brakes.
That's what you paid for. Get your money worth back out of them. Do not take NO for answer. It's brakes, your life depends on them. Dealers tend to go soft, when you loudly use words like SAFETY, LIFE THREATENING. And have every piece of documentation from them. Just in case. Nothing "on word". They say it's normal - On paper, please.
Old 07-22-19, 07:05 PM
matmelt
matmelt's Avatar
Thank you for the response ! I will end up taking it to the dealer. If anyone else may know what I am in for let me know. Also do you think this is covered under warranty?
Old 07-23-19, 05:56 AM
16fsport2
16fsport2's Avatar
For some reasons, my browser does not play your video.
However, IMO if the nature of the problem is not due to wear and tear, your '16 NX has 4 years bumper to bumper warranty and within corresponding mileage limit. Since your ODO is only 15K and if the brakes don't work properly, I'd say you're covered under such warranty.
Old 07-23-19, 09:39 AM
ukrkoz
ukrkoz's Avatar
Pads are not covered under any warranty. they are normal wear item. But that is, when pads wear out and start making indicator noise. Not what you experience. That is different, that is brake system concern. And anything related to owner safety tends to be very sensitive with dealers, as if life happens, it's a hefty lawsuit following. So brakes, restraint systems, all that new radar cruise control, etc - anything safety is making them nervous.
You just need to play it right, as like I bet before - This is normal will be response.
Old 07-24-19, 02:44 PM
NXOwner
NXOwner's Avatar
Location: Driving a UX Hybrid F-Sport! (in So California)
What was the outcome of your dealer visit?
Old 07-27-19, 02:00 PM
matmelt
matmelt's Avatar
its at the dealer now. waiting for them to let me know what they think. have you had this issue before?
Old 07-31-19, 08:27 PM
matmelt
matmelt's Avatar
Well on the service sheet they addressed the front but they didn't seem to address the rear. So taking it back to the dealer.
Anyone have my same issue ? Any fixes out there?
Old 08-07-19, 07:52 PM
matmelt
matmelt's Avatar
Anyone else know what could be occurring?
the dealer just greased up the pads I think. Going tomorrow to pick it up so I'll see.
I just don't understand how a Lexus can do this....
Quick Reply: brake sound in reverse
