Engine coolant leak
Old 07-18-19, 03:10 PM
Hog300
Hog300's Avatar
Default Engine coolant leak
Leaking of fluid
The picture is taken from crawling under the vehicle behind the front wheels and taking picture in the direction of the front.
Yesterday I took our 05 GX 470 for a trip and noticed the temperature gauge was reading hot. I've never had issues until yesterday. I bought some coolant and replaced 1 full jug to get it to the correct level. The next day a drove it for a short trip to the gas station. While fueling up I noticed engine coolant dripping on the concrete. The picture is where the drip occurs. I can't find and leaks on top of the engine. Any suggestions?
Old 07-18-19, 04:08 PM
MrJason
MrJason's Avatar
My guess would be one of 2 things leaking...
- the hoses that connect to your heater core inlet and outlet tubes(pictured)...
-your heater core is leaking and the coolant is coming out the evaporator drain and dripping onto the side of the engine. This may be why you didn’t notice a leak.. it could be mixing with the water that normally drips out.
Im guessing the clamp(s) on your hoses connecting the cooling system to your heater core is the most likely issue... since it appears to be coming from the upper left side of your engine bay and dripping down around the bell housing area.
The heater core would be more noticeable on the opposite side.
Check these clamps...
Old 07-18-19, 06:04 PM
Hog300
Hog300's Avatar
It is dry as a bone on the hose connecting where you pointed out on the diagram. I would think that when I turned on the heater full blast I would smell antifreeze if the heater core was the problem. Are there any hidden hoses that could leak but pool down a low spot to the bell housing?
Old 07-18-19, 06:44 PM
IanB2
IanB2's Avatar
Just to the left and back along the block from where you took your pic is a block drain, maybe it's come loose and is dripping, and blowing back onto the transfer case? It is the transfer case with the coolant collecting on it, right? Hard to tell for sure in your pic.
MrJason (07-18-19)
Old 07-18-19, 08:08 PM
MrJason
MrJason's Avatar
I stand corrected on this. I believe IanB2 nailed it.
Old 07-18-19, 08:23 PM
Hog300
Hog300's Avatar
I don't think it would be a block drain leak. No work has been done to the engine and only been on the highway. I'll try to locate to make positive.
Old 07-19-19, 02:37 AM
dblshock
dblshock's Avatar
Coolant looks green to me, if so it's the wrong coolant, not a fix but stop using it.
Old 07-19-19, 04:26 AM
Hog300
Hog300's Avatar
The part store said the same thing about the green coolant. They informed me once the leak was detected that Asian red was to be replaced. I thought the universal green would at least not coagulate since it was leaking green in the first place. Thanks for everyone's input! I really love this forum. Great community of knowledge.
Old 07-19-19, 06:05 AM
Hog300
Hog300's Avatar
Here is the picture of my block drain? I took this picture from underneath behind driver front tire.
Old 07-19-19, 06:09 AM
Hog300
Hog300's Avatar
Here is better picture of where the dripping is on the front side if the bell housing.
This picture is from the driver side shot toward the front.
Old 07-19-19, 06:13 AM
Hog300
Hog300's Avatar
No leaks from these hoses either
There are no leaks coming from the top of the engine from any of the hose connections to the fire wall.
Old 07-19-19, 06:56 AM
Hog300
Hog300's Avatar
I took it for a drive this morning with the heater on for about 6 miles. The heater never blew hot and there was no leak. The temperature gauge stayed in the middle as well. I then took it for another 8.5 miles immediately after this 6 mile trip. The heater started blowing hot and after the 8.5 mile trip the drip started showing up again. The temperature gauge stayed in the middle both trips. I'm sure the coolant level had not be drained out enough to cause overheating issues. I'm pretty sure I know what's wrong but I'd like to hear other's diagnosis here for confirmation.
Old 07-19-19, 07:52 AM
IanB2
IanB2's Avatar
The block drain and hoses on the firewall look dry to me. What's your theory?
Old 07-19-19, 02:37 PM
chiph9
chiph9's Avatar
Loose freeze-plug?
Chip H.
Old 07-19-19, 02:57 PM
Rygar470
Rygar470's Avatar
Question out of the norm; When was the last time you did the TB/WP job?
Quick Reply: Engine coolant leak
