Brakes replacement is350
Hey guys I've been researching replacement brake pads and rotors and there are so many options just looking for some advice. I'm looking for a cross and slotted design with a street performance pad or anything else you guys can suggest that isnt garbage.
I've also done the front brakes before and it always seems I end up with pulsing down the road even with a proper break in procedure. Is there anything that can cause this or is it just the pad transfer material. Which I try to avoid by breaking in properly and taking my foot off the brake after a emergency stops. Thanks in advance.
Stoptech slotted axle packs .
What pads do you get pulsing with? Do you hold the brakes at a stop light? During break-in, you should avoid holding the brakes at a stop light at all costs (usually this means shift into neutral and use the parking brake as necessary) while tapping the brakes as people behind you approach so they know to slow to a stop.
Parts geek , jegs , anywhere that you can enter your email and get a little discount. They have different offerings available. I wanted the black hub and slotted for a little better look. The whole kit was around 520.00 but they have cheaper sets. They’re made by Centeic , so the quality is solid. I can’t remember if they’re ceramic or not unfortunately.
lexus_west
06-21-09 05:22 PM
