Car Speaker popping very loudly!!
Old 06-19-19, 10:23 PM
Cisco350
Cisco350's Avatar
Default Car Speaker popping very loudly!!
So I believe I know what the issue is I’d just like to know if it’s a problem where I should reverse what I did or if there’s a fix for me to keep what I did.
I recently installed new leds in the map front map lights and new led in the doors just yesterday. I don’t hear any issues before I get in or while driving the car. But when I turned it off the car you can hear the speakers popping very loudly. Like 30ft away loudly even though the volume was at 0.
So so is there anyway to fix this? Will leaving it cause damage? Is my battery dying? Is it the LEDs?
Map LED: https://www.amazon.com/dp/B07BT23WVC/ref=cm_sw_r_cp_api_i_lCXcDb1TKAMP1
Door LED:https://www.amazon.com/dp/B07NP7R6GS/ref=cm_sw_r_cp_api_i_QFXcDbPXH2RHH
Old 06-20-19, 08:35 AM
Cisco350
Cisco350's Avatar
https://imgur.com/gallery/3aYNwpj
Here's a clip of the sound. Sounds like its coming from stereo.
Old 06-20-19, 08:45 AM
Cisco350
Cisco350's Avatar
Oh I've also removed both those LEDs and its still making the noise. So idk. I do also have a bluetooth aux adapter in the car but its not plugged in.
Old 06-20-19, 01:59 PM
Gville350
Gville350's Avatar
So the stereo system makes a loud POP noise through the speakers when you turn the car OFF?
Old 06-20-19, 02:09 PM
Cisco350
Cisco350's Avatar
Yes. It continues long after its been turned off too.
Old 06-21-19, 07:47 AM
Drizell
Drizell's Avatar
Only thing I could find on that was about Interrupted Current. One of the most common causes of popping and crackling sounds from speakers is an interrupted current.. Check wires for the LED door light, make sure no exposed wires touching anything. Make sure things are grounded or insulated. Make sure the battery connection under the hood if you have attached any additional wire connection to the termal.
Old 06-21-19, 12:36 PM
xxmariolxx
xxmariolxx's Avatar
Map LED: https://www.amazon.com/dp/B07BT23WVC..._lCXcDb1TKAMP1
Door LED:https://www.amazon.com/dp/B07NP7R6GS..._QFXcDbPXH2RHH
Can't help you with the popping noise but open up those projector LEDs and adjust them. I have the same exact ones and at first they looked cheap and awful just like on your pic. I opened them up and adjusted them. I actually had to cut a little plastic to adjust them right. But now they look really good and not all stretched out
Old 06-21-19, 01:30 PM
Cisco350
Cisco350's Avatar
Adjust them how? like whatd you adjust?
Old 06-22-19, 02:18 PM
xxmariolxx
xxmariolxx's Avatar
Open them up and you'll see. I even ended up cutting a little plastic inside to adjust them to where they weren't all stretched out. Adjust the actual light. The way they're made factory seems like it's meant to be flat but how our cars are they're not leveled so you have to compensate for that
TonyLx570
LX - 3rd Gen (2008-2021)
10-09-20 05:35 PM
s2000zr
RX - 4th Gen (2016-2022)
14
03-12-16 12:11 AM
chris07is
02-21-14 07:42 AM
wheelwh0re
12-04-11 01:15 AM
bluelex
Lighting
03-27-05 12:38 PM
Quick Reply: Car Speaker popping very loudly!!
