ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Is Your HUD Displaying at a Slant?
Old 06-16-19, 02:41 PM
RJLsES
RJLsES's Avatar
Default Is Your HUD Displaying at a Slant?
The HUD on my 2019 ES350 F-Sport displays at a slant. The left side of the display is tilted down at about a 5 degree angle. It's just not level with the horizon.
It's not a big deal, really. But I wonder if a Lexus tech could go under the dash and tweak the display so that it would display level.
Any thoughts?
Old 06-16-19, 02:47 PM
Tootsall
Tootsall's Avatar
Do a quick search for "HUD tilted". There are existing threads.
Old 06-16-19, 03:04 PM
RJLsES
RJLsES's Avatar
Thanks for the tip. I'll try to put a small bubble level on my dash to see if it's actually level and verify that I'm just experiencing an optical illusion.
Old 06-16-19, 04:06 PM
mikemu30
mikemu30's Avatar
Received 2,322 Likes on 1,678 Posts
It can be adjusted in HUD settings. See page 79 of the owners manual.
Old 06-16-19, 05:15 PM
95bat
95bat's Avatar
Received 1,208 Likes on 630 Posts
Just tilt your head a little the other way
Old 06-16-19, 05:26 PM
mikemu30
mikemu30's Avatar
I have it but never use it.
Old 06-18-19, 04:03 AM
CJS57
CJS57's Avatar
The HUD is slanted. Right side dips down to the right and left side dips down to the left. There is an adjustment for this but it does nothing. I just got used to it after 6 months now.
Old 06-18-19, 08:28 AM
Woodrow
Woodrow's Avatar
As you adjust the rotation of your Head Up Display, notice that you can align it to either the car or to the horizon as a reference. I was using the dash as a reference, but with my car, there isn't enough adjustment to make the display align properly. It still looked crooked. The horizon also works as a reference, but if I do that, the display looks even worse. I think this is because my brain (such as it is) naturally uses the line of the hood as a reference because it's closer. In the end, I decided it's an optical illusion and decided to go with the horizon. Like CJS57 did, I just got used to it.I simply don't notice it anymore.
Old 06-19-19, 05:38 AM
ES63
ES63's Avatar
Originally Posted by Woodrow
As you adjust the rotation of your Head Up Display, notice that you can align it to either the car or to the horizon as a reference. I was using the dash as a reference, but with my car, there isn't enough adjustment to make the display align properly. It still looked crooked. The horizon also works as a reference, but if I do that, the display looks even worse. I think this is because my brain (such as it is) naturally uses the dash as a reference because it's closer. In the end, I decided it's an optical illusion and decided to splitting the difference with the adjustment, and like CJS57 did, I just got used to it.I simply don't notice it anymore.
Same , it rotates just not enough to compsate for the glass curvature, its interesting , the hight can actualy be over-adjusted to where it gets cut off from the dash .
just quirks , but i absolutley love having the HUD
Old 06-19-19, 11:38 AM
RJLsES
RJLsES's Avatar
Ah, it was more of an optical illusion. The HUD appears level against garage shelves in front of the car when parked. So my complaint about the slanting HUD display was in error.
Thanks to all who commented.
mcfancy
RX - 4th Gen (2016-2022)
04-05-18 06:54 PM
GS300ToM
14
07-20-11 12:07 AM
GS300ToM
60
06-25-11 06:58 PM
Quick Reply: Is Your HUD Displaying at a Slant?
