Using Key FOB to Auto down windows - one window not working
2007 Lexus RX 350
Summary:
I had to replace the Left Rear window switch a while back. Afterwards, it would only go 1/2 way down when holding the Unlock button on the key FOB. All others work fine. I could live with that.
Today I installed WeatherTech vents and ended up having to disconnect the battery because I could not get the Front Right window to reset and stay up.
Now, the Left Rear window does not go down at all when holding the key FOB unlock button.
Is there a program reset that I need to do to reset the key FOB window Auto-down function?
Summary:
It works normally from both window switches?
That's what I'm trying to find out. . . . . . is this a DYI reset or a factory Stealership reset?
Is it a reset, reprogram??
It's must be somehow related to the left rear window switch. Is there a sequence that has to be done to get it to sync with the key FOB?
