IS-F oil changes at home...
Old 06-15-19, 11:06 AM
xdejablu3x
xdejablu3x's Avatar
Default IS-F oil changes at home...
Just curious to see what people are using at home to dow their own oil changes and what suggestions they have for doing so. I finally picked up my F yesterday and excited to finally own one. Was thinking about getting some Rhino ramps but wasnt sure how durable they would be for our car.
Old 06-15-19, 11:14 AM
WillAP1
WillAP1's Avatar
Not sure if rhino ramps are low profile enough to work. I use race ramps and measured to make sure they would clear. I got the 2nd lowest profile option and its still a close fit. If I lower the car I will probably need extensions to clear. They are pricey but worth the piece of mind IMO.
Old 06-15-19, 11:27 AM
xdejablu3x
xdejablu3x's Avatar
I honestly dont think they will clear but I have some wood that I used on my old car that was lowered to help get on there. Mine is on stock suspension so that helps at least.
Old 06-15-19, 04:02 PM
RRocket
RRocket's Avatar
I use rhino ramps....no problems.
Old 06-15-19, 06:10 PM
newgsman
newgsman's Avatar
I use two jacks. First I use a jack at the pinch seam jacking point under the front door to bump up the car so that I can slide my bigger jack all the way under the middle of the engine cradle frame. I then jack up the whole front of the car up so that I can place jack stands under the front frame rails. It's a bit of a chore but I find it better than using ramps, although my ramps are the steal ones so I can't say how good the Rhino ramps would be.
Old 06-15-19, 06:52 PM
isfvss
isfvss's Avatar
Just make your self some ramps out of 4x2 cost bugger all cheers.
Old 06-15-19, 06:56 PM
ThisOldNSX
ThisOldNSX's Avatar
I also use rhino ramps just fine.
Old 06-15-19, 07:07 PM
BennyISF
BennyISF's Avatar
Weird Rhino ramps didn't work for my F.
Old 06-15-19, 07:14 PM
xdejablu3x
xdejablu3x's Avatar
Yeah, seeing how low the car is from stock I was wondering what are other peoples methods on getting to their rhino ramps? I get that you may need longer boards of wood depending on your driveway, garage or whatever. I can't do it in my drive way because I have a very steep inclination to get into my garage, which really is no bueno for even some regular stock height vehicles as well.
Old 06-15-19, 07:46 PM
tas02
tas02's Avatar
I do what Newgsman does in post #5, with one exception: I jack the rear up as well & put the car on 4 jack stands so it's level and all of the oil gets out.
Old 06-16-19, 12:21 AM
MileHIFcar
MileHIFcar's Avatar
Just don't do it this way:
Old 06-16-19, 07:54 AM
xdejablu3x
xdejablu3x's Avatar
Poor Guy
Oh yeah. I saw this awhile back. This is something all of us are trying to avoid. For those of you guys have just lifted the front end via ramp, Jack's or whatever, how much oil comes out since the vehicle is at an inclination at this point?
Old 06-16-19, 09:02 AM
j3ff
j3ff's Avatar
The drain hole is actually facing the back end of the oil pan, so lifting the front slightly is okay. I usually get around 9-9.5L out per drain.
v8sedan (09-05-19)
Old 06-16-19, 01:23 PM
ultimase
ultimase's Avatar
Poor Guy
LOL ouch, but why would you not visually confirm that you're on the jack point?
Old 06-16-19, 04:24 PM
RRocket
RRocket's Avatar
Yep...I'd say the ramp might even help a bit in that regard.
Though we're probably splitting hairs.
Quick Reply: IS-F oil changes at home...
