01 RX300 Transmission dead- rebuild or replace?
Old 06-04-19, 01:55 PM
Seee
Seee's Avatar
Exclamation 01 RX300 Transmission dead- rebuild or replace?
I've done as much research as i could on the subject and am stuck now. Car ran fine and one day it just rolled to a stop. No forward or reverse. Researched a bit and changed the tranny filter and shift solenoid 4 to no avail. Car still does not move. I did find larger chunks of metal in the oil pan which has lead me to believe it's a bigger problem than just line pressure and solenoids. Now my question is, would you replace the tranny with a used tranny and risk it happening again or remove this tranny and have that rebuilt? Anyone care to chime in with your experiences. Car has 230k miles and has had no issues except now. Any advice would be greatly appreciated. Thank you.
PFA:
Old 06-04-19, 02:02 PM
JAB
JAB's Avatar
Have a remanufactured unit installed. Been there done that.
Old 06-04-19, 03:24 PM
sktn77a
sktn77a's Avatar
Don't be tempted to install a used tranny (unless it's been rebuilt).
Old 06-04-19, 03:41 PM
JAB
JAB's Avatar
Curious as to how long you have owned it and how frequently (if ever) you have changed the tranny fluid.
Old 06-04-19, 03:52 PM
carguy07
carguy07's Avatar
Disconnect the battery and re-boot the computer just for grins.
Old 06-05-19, 07:14 AM
salimshah
salimshah's Avatar
What are your long term plan after the fix. It is an investment and you need to share [really think it out] about
a) street value after repair
b) How long you plan to keep it and how do you intend to part
Salim
Old 06-18-19, 04:19 AM
Redpaint
Redpaint's Avatar
Default Why is there no class action lawsuit for 99-01 rx300
Why are we not fighting back!!
Old 06-20-19, 06:52 AM
fastnoypi
fastnoypi's Avatar
majority of these transmissions blow up well after the non-transferable warranty period......and these 1st gens are almost all 20 years old. FWIW...the issues found in the valve bodies and other transmission components used in these 1st gens (U140) have been identified by a handful of aftermarket companies. Sonnax as an example. https://www.sonnax.com/units/209-u140f
Old 06-20-19, 07:03 AM
fastnoypi
fastnoypi's Avatar
If the OP plans to keep the car.. I would go the remanufactured transmission route and have the local Lexus/Toyota certified tech scan/test the PCM for any faults that may have caused the previous transmission to go bad. Here is a diagnostic article for the U140 that may or may not apply to symptoms leading to the transmission failure that maybe an interesting read https://www.sonnax.com/tech_resource...ic-information
Old 06-20-19, 08:57 AM
JAB
JAB's Avatar
Wow. An invaluable resource.
Old 06-26-19, 08:16 AM
RX469
RX469's Avatar
Originally Posted by Seee
PFA:
Hi, I hope you're able to get your transmission issues resolved and get your RX back on the road soon! !
That said, your RX is the first I've seen with those wheels and such tires for an exciting and refreshing look on an RX300. I've watched this thread for like a week each day looking at your RX. It's a beautiful RX. Do you have anymore pics of your RX showcasing your setup to share. Thanks!
Old 06-26-19, 10:43 PM
Bill Dowd
Bill Dowd's Avatar
I replaced my transmission at 155,000 3years ago and no problems as yet. I am using Max Life synthetic trans fluid since the rebuild and put on a trans cooler for a cooler running trans.
My trans guy l put in hardened planetary gears that is the weak point on the first few years on the Lexus RX 300 trans.
You are at 230 K miles is the rest of the vehicle in good condition then it might be worth fixing the old trans, if it is only fair condition I would look for a 2005 or newer one.
These RX300's can go 300,000 to 400,000 miles if taken care of.
Old 06-27-19, 12:40 PM
RX469
RX469's Avatar
What year is your RX?
Old 06-27-19, 11:31 PM
Bill Dowd
Bill Dowd's Avatar
My RX300 is a 2001 model with 175,000 miles, I have driven Toyota's over 500,000 miles an 1986 Cressida using all synthetic oils and nothing wore out.
1991 Lexus LS 400 drove to 400,000 miles it's still on the road again all synthetic fluids, Nothing ever wore out
And other old Camrys up to 350,000 miles each used them for long haul sales work. I never lost a trans till the 2001 RX 300 due to the people before me only changed the trans oil one time at 120,000 miles.
I change my trans oil at 25,000 using Max Life synthetic fluid also used in my power steering..
Old 06-28-19, 10:00 PM
gookies
gookies's Avatar
You'll see that the U140 transmission isn't that reliable and most aftermarket companies that rebuild them upgrade certain components, like your trans guy did. There have been individuals in here that have changed their transmission fluid religiously and still had their transmission blew up. Mine blew recently and it's not worth fixing to me, imo. Just going to sell it as a mechanics special or something.
164KRX300
01-19-13 07:39 AM
gs300_tx
GS - 1st Gen (1993-1997)
05-19-10 08:27 PM
nar8ta
07-18-08 12:27 AM
David GS400
Performance
12
05-14-06 06:34 PM
KevinGS
05-07-06 12:14 PM
Quick Reply: 01 RX300 Transmission dead- rebuild or replace?
