Brake fluid flush before or after?
Old 05-19-19, 07:58 AM
Sportznuts
Sportznuts's Avatar
Default Brake fluid flush before or after?
I知 purchasing new OEM brake pads and OEM rotors for my 80,000 mile LS. I知 getting the brakes installed by an Indy, flush done by Toyota.
Stupid question......
Should I get the brake fluid flushed before or after I have the brakes installed or does it not matter either way?
Anything else brake related I should have done at this mileage?
Old 05-19-19, 08:34 AM
fwhomeboy
fwhomeboy's Avatar
Did you get the parts free? Like a warranty deal? If you have to pay then I wouldn't go with the OEM parts.
Old 05-19-19, 09:22 AM
Sportznuts
Sportznuts's Avatar
I already purchased the OEM brake pads on eBay for $140. I was planning on purchasing the OEM rotors, front and back, $406 shipped.
I do notice the current brakes don稚 have very much feedback.....
Old 05-19-19, 10:47 AM
fwhomeboy
fwhomeboy's Avatar
Did you read the Brakes and Rotors thread on here before you decided?
Old 05-19-19, 03:28 PM
sha4000
sha4000's Avatar
It really does not matter unless you were changing the calipers.
Old 05-19-19, 03:50 PM
tx170754
tx170754's Avatar
I知 at 36,000 miles and my original rotors are already warped, I would not buy OEM ones, just my .02
The following 2 users liked this post by tx170754:
fwhomeboy (05-19-19), mambo619 (05-20-19)
Old 05-19-19, 05:32 PM
Sportznuts
Sportznuts's Avatar
Originally Posted by FunFact
It does matter, because when you change pads you want to clean the area around the pistons and then push them in. While there are seals, it's not 100% sealed to the point of nothing getting past them. If you have fresh fluid, you just contaminated them. If you flush it post-pad swap, it doesn't matter because you're getting fresh fluid.
So, brake fluid flush post-pad swap. 👍 😀
Old 05-20-19, 11:17 AM
sha4000
sha4000's Avatar
If he were doing the swap and flush at the same place I would recommend doing the flush before the change without a doubt. Since he is using 2 different places to do the work IMO it doesn't really matter. You can't go wrong either way it's done.
Old 05-20-19, 04:27 PM
jkittlesen
jkittlesen's Avatar
Hey Sportz how many miles on that '91 ?
Old 05-20-19, 06:07 PM
colfax
colfax's Avatar
I would not either, I bought an 07 460 a year ago with 105,000 miles, needed front rotors and pads right away
based on the opinions on this forum I called rockauto.com and got all new good stuff for around $300, very happy
Old 05-20-19, 06:27 PM
PwrdbyM
PwrdbyM's Avatar
The real answer is it doesn't really matter, however I think by doing the hardware change second you run more risk of introducing air into the system by compressing pistons, accidentally un-torqueing a brake line, etc. To minimize risk I'd do the flush after the hardware change.
Old 05-20-19, 07:32 PM
jkittlesen
jkittlesen's Avatar
Meant to be off topic!
Curious is all!
Old 05-22-19, 09:01 AM
roadfrog
roadfrog's Avatar
If it were me, I'd do it after. For all the reasons stated.
Old 05-22-19, 10:37 AM
ALK
ALK's Avatar
I would do it after brake job . Because if the current fluid level is max removing the pads will make the level rise above the max , therefore overflow could occur.
Quick Reply: Brake fluid flush before or after?
