Alarm goes off intermittently- any ideas as to why?
Old 04-23-19, 08:14 AM
campfire
campfire's Avatar
Default Alarm goes off intermittently- any ideas as to why?
A coupe of times now it just goes off. Usually about 1/2 after locking it. Any guesses? Thanks in advance.
Old 04-23-19, 01:11 PM
GXinSD518
GXinSD518's Avatar
I remember reading a while back that the door jamb close/open sensor on the rear barn door can go bad and send a false open signal, causing the alarm to go off. It's usually a pretty cheap and easy part to replace.
The following 2 users liked this post by GXinSD518:
campfire (04-26-19), IanB2 (04-24-19)
Old 04-23-19, 06:25 PM
chiph9
chiph9's Avatar
Another vote for a bad cargo door switch.
Chip H.
The following 2 users liked this post by chiph9:
Old 04-24-19, 05:04 AM
Rygar470
Rygar470's Avatar
Mine used to do this but it wasn't the rear barn door, as much as it was the settings. Once I played with the alarm setting via Techstream, I was able to set the alarm the way I needed it to.
PS: The settings went crazy after a battery disconnect.
campfire (04-26-19)
Old 04-24-19, 05:17 PM
campfire
campfire's Avatar
I'm going to try the techstream. On weird thing too is the right front turn signal goes out for no reason, then stars working again.
Old 04-24-19, 06:39 PM
Rygar470
Rygar470's Avatar
Hmm. It probably isn't related. Then again, check to see if the hazard button works, as well as the right/left turn signals as intended. On some vehicles, this is an indication that the hazards/intermittent button is on its way out. YMMV.
campfire (04-26-19)
Old 05-06-19, 05:43 PM
aljodoro
aljodoro's Avatar
Default I vote for door switch
My car alarm would go off after the car had been parked. It was the rear door switch. The switches are very easy to remove. You probably could remove all 5 and see if that solves your problem. They do not have to be installed but you will lose your interior light when opening the door. . Of course you have the issue of determining which one. It tried a multi-meter but did not find that it told me anything which I expected by the nature of the problem. When the door is closed it is an open circuit and when opened it is a closed circuit. I suppose you could tape all five switches closed and check periodically for continuity. Chances of this working are pretty slim in my opinion. Maybe just buy a new one in put in the tailgate. That is the most likely culprit.
campfire (05-07-19)
Old 05-06-19, 06:25 PM
campfire
campfire's Avatar
Thanks, just ordered one. I'll post my findings. Thank you all!
Old 05-06-19, 08:07 PM
IanB2
IanB2's Avatar
I'd replace the rear hatch sensor first, and keep the old one. If the problem persists, start changing the others one by one with the old ones until you find the culprit. It could be humidity related if it's an intermittent failure, so look for torn boots on the sensors or that kind of thing.
The following 2 users liked this post by IanB2:
campfire (05-07-19), Rygar470 (05-07-19)
Old 05-07-19, 12:20 PM
Rygar470
Rygar470's Avatar
Yep, the old "Process of Elimination."
campfire (05-07-19)
Old 05-08-19, 04:46 AM
MrJason
MrJason's Avatar
Open your rear door and see if your cargo lamp comes on... then push the item pictured in and out... see if the light works with each slow push and hold.... if it does, check the other 4 doors the same way.
This switch should work in which ever door isn’t activating the cargo lights... but make sure your cargo lights are set to “door” on their housings.
EDIT..... I’m not sure why this statement about a blinker is on here. Lol
Your blinker bulb most likely has a weak filament and needs to be replaced. I’d also clean the socket while when I replaced the bulb. There are plenty of threads on how to replace these bulbs.
Old 05-24-19, 06:03 AM
campfire
campfire's Avatar
Update, I changed the cargo door switch, and so far no alarms. Thanks to all!
The following 2 users liked this post by campfire:
MrJason (05-24-19), Rygar470 (05-25-19)
rolf
05-23-10 02:17 PM
rwdanthony
07-09-08 12:14 AM
Quick Reply: Alarm goes off intermittently- any ideas as to why?
