Lexus is250 2010 No Audio!!! Please help!!
Old 04-17-19, 02:29 AM
Dwayne274
Dwayne274's Avatar
Default Lexus is250 2010 No Audio!!! Please help!!
Okay you guys I have a Lexus is250 2010 rwd base model includes navi so anyway I have no sound from any thing when I hit the Audio button it just says no audio the guy I purchased it from saying factory amp can someone give me some advice????
Old 04-17-19, 09:29 AM
maeveLexi
maeveLexi's Avatar
Check your fusebox on the driver's side.
I had the same thing happen to me and it was just a blown fuse.
Hopefully its the same fix for you.
Old 04-17-19, 06:10 PM
Dwayne274
Dwayne274's Avatar
Default Audio off!!!
Well what Lexus do you have because I don’t have any radio fuses on my driver side
Old 04-17-19, 10:24 PM
Zmon
Zmon's Avatar
Either fuses or the amp. Fuses are labeled radio #1 and #2 in the engine compartment (driver side, need to pull off another cover once you're in to access the fuses), both are 30A. If those are good, I'd bet on the amp being the issue then. Check the trunk, it's on the right under the cover. I'd check for any water, or any damp feeling on your carpet there as it's fairly common for the vent to deteriorate and allow water in which kills the amp, see https://www.clublexus.com/forums/is-...amps-fail.html
Old 04-18-19, 12:25 PM
maeveLexi
maeveLexi's Avatar
I have a 2008 IS 350 but like Zmon said, its on the engine bay right above where you put windshield washer fluid in.
And if I remember correctly, the fuse is on the bottom left in the fusebox and it should be a yellow fuse.
Old 04-18-19, 01:30 PM
Dwayne274
Dwayne274's Avatar
Default Audio off!!!!
Alright you guys I check the fuses their all good so I went to the trunk and yes my amp is rusted out I could barely remove the wires so do you guys suggest this is the cause for my no audio???
Old 04-18-19, 01:48 PM
Zmon
Zmon's Avatar
I'd more than bet that's the reason. If you really want to know, take it to just about any car audio place and have them test it. I think there's a few places that repair them, United Radio being one. That's an alternative if they quote you a lower price than buying a used one off of eBay for $200. Since you're in NO, I think there was a place in Harahan that repairs amps, you'd have to look around and give them a call though. Also, how was that flap that I said to check? You're gonna need to replace that too most likely.
Old 07-09-21, 02:04 PM
phillyIS25
phillyIS25's Avatar
Default Fuse Might not be broken but needs replaced
passenger side panel 10amp Fuse. If the sides are black or look burnt. A new fuse is like $4-5. Audio stopped in my IS250 2008 AWD. Again if that arch in the middle isn’t broken it does have to be go right to AMP.
Old 06-26-22, 05:10 PM
808isf
808isf's Avatar
Ok so I'm having this problem. Where my deck is saying no audio. Power button for audio dont turn it on.Checked all fuses. Just looked at my amp. It's not rusted or anything just hot like a normal amp would be. All my fuses r ok. Any other suggestions ?
Old 09-07-22, 07:21 PM
Jdmmoi
5th Gear
Jdmmoi's Avatar
Default 06 350 ml system
Ok so my car is having same issue I took amp out and cleaned it with a air gun put it back in turned car on and worked. But then about 2 hours later went to turn car on and no I don’t have any audio. I can’t use volume and when I go to the Audio settings it just stays to the bottom right corner and doesn’t let me change it. Can a fuse have blown or is my amp toast. I’ve been having problems with my audio since the beginning of the year. Hopefully it doesn’t come to the case where I need a new amp
MolonLabe
09-03-22 06:10 PM
RX270
RX - 3rd Gen (2010-2015)
19
05-12-22 09:04 AM
Shaq32
08-10-17 12:46 AM
geazy
04-27-16 02:01 PM
arlow9
09-05-13 07:03 AM
Quick Reply: Lexus is250 2010 No Audio!!! Please help!!
