Replaced valve cover seals and still leaking
I replaced the valve cover seals on the passenger side because the ignition coil closest to the front of the car was flooded with oil. Replaced the rubber seal that sits in the top of the coil too.
The problem is I think it got worse.
Any ideas what else it could be? I don’t think my mechanic used oem part. Would that be an issue?
Just to be clear, your valve cover gasket replacement also included the round inner gaskets that cover the plug holes? These are likely the culpret given your problem. Many times these can fail and not the outter main gasket, which means the owner never sees any external oil drips but the plug hole is covered in oil. I'd confirm these were also replaced and properly installed.
Are you sure it was the velve cover seals and not the fuel pump seals? Maybe the mechanic replaced those too (I would have, since you’re already “there”). I had what I thought were leking valve covers, and it turned out to be fuel pump seals.
I just placed an order for the spark plug seals hoping that will solve the problem. The funny part is only some plugs have oil in them, not all.
Measured
06-05-15 02:30 PM
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
02msmg3
12-16-10 10:50 AM
