Where is the power steering ECU located?
Old 03-20-19, 11:47 PM
Luxurious
Luxurious's Avatar
Default Where is the power steering ECU located?
Trying to find out where its located to replace it.
https://www.ebay.com/itm/98-05-Lexus...4383.l4275.c10
I believe that's the correct part. Anyone know how to get to it? Is it difficult or wheres the location?
Please help.
Old 03-21-19, 06:24 AM
captainva
captainva's Avatar
In the drivers side foot well up under the dash to the left a little bit. Not to bad to get to. It took me about 10 minutes to remove and replace when I changed my flasher relay to a tap turn. Thats a total PITA to change out.
Old 03-21-19, 02:55 PM
Luxurious
Luxurious's Avatar
Thanks Muff! Do you need to get the same year for your car or 98-05 work on all the same?
Old 03-22-19, 06:17 AM
captainva
captainva's Avatar
All years are compatible with each other. The only sport ECUs are in the Sport Design and L-Tuned and the 430 had the normal ECU from my understanding. Also see the bottom of this thread. Sakataj uploaded the install guides from the L-Tuned steering ECU.
https://www.clublexus.com/forums/gs-...ering-ecu.html
Old 03-22-19, 09:54 AM
Luxurious
Luxurious's Avatar
Great, thanks for the info man. Went ahead and bought the ECU so hoping to see a difference for sure.
Old 03-22-19, 11:53 PM
shwalker07
shwalker07's Avatar
Keep us updated after the install.
NoahAA
09-07-17 02:13 PM
SprtDesign
11-07-13 12:33 PM
Red Bully
02-19-13 12:37 PM
bad-gs400
Suspension and Brakes
47
06-27-02 01:55 PM
disc108
04-12-01 01:10 AM
Quick Reply: Where is the power steering ECU located?
