IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Accelerator pedal jerking on its own
Old 03-20-19, 03:18 PM
PrisyCrisy
PrisyCrisy's Avatar
Default Accelerator pedal jerking on its own
So, my safe mode idle issues are back. But this time I noticed that when it’s in limp (safe) mode that while I am trying to putt home and lose about 30% pedal pressure I could actually feel the Accelerator pedal jerking on its own to idle.
Now this seems Really freaky to me... I thought Lexus didn’t have issues with the pedal accelerating on its own?
And I’m baffled as to why there is no code but yet the limping persists?!?!
Could it be a bad ground?
i wouldn’t think the O2 sensor codes (P0430 & P0031) would have anything to do with the idle.
Thoughts.....???!!!!
Thanks in advance,
Christa
Old 03-21-19, 05:13 AM
daddystop
daddystop's Avatar
O2 sensors are heavily tied into how the car idles. It's a feedback loop. Make fueling correction to maintain steady idle rpm -> check o2 sensor -> make correction based on o2 sensor to fueling or ignition timing (for finer RPM adjustments). I 100% would not expect your car to operate properly if it thinks the o2 sensors are not working.
The reason you can feel movement in the medal is because the ECU is actuating the throttle motor that is connected to the pedal's cable. I've never felt it in my car but my car isn't doing what yours is...... I would assume the movement you're feeling is normal.
Old 03-21-19, 05:58 AM
PrisyCrisy
PrisyCrisy's Avatar
Okay, thank you for answering!
Now.... my only problem is that I do not have an OBD II scanner.
Many suggestions on where or how I can get this checked?
Old 03-21-19, 06:35 AM
daddystop
daddystop's Avatar
Autozone, oreilly, advanced, or whatever local parts store is by you. They will usually scan codes for free.
If you're an android phone user (I am not).... there are several "cheap" solutions that have bluetooth obd2 readers. The software on your phone is called "torque" and it's a free download.
An example that would probably work:
https://www.ebay.com/itm/ELM327-WiFi...frcectupt=true
Old 03-21-19, 06:36 AM
daddystop
daddystop's Avatar
If you're an iphone user then I would suggest buying a hand held obd2 scanner because all the apps that would do what Torque on Android does cost money.... just use that money on a better piece of scanning hardware rather than paying for software that is given away free by other vendors like Torque.
Old 03-21-19, 12:47 PM
PrisyCrisy
PrisyCrisy's Avatar
Thanks
I ended up ordering the BlueDriver OBD II
app is free, comes highly recommended.... works great with Toyota!
Old 03-22-19, 06:55 AM
daddystop
daddystop's Avatar
That one you ordered should work on most other vehicles too.... so now you can help your friends.
Old 03-22-19, 11:05 AM
PrisyCrisy
PrisyCrisy's Avatar
I know!!
i wonder if I can use it on my 97 Celica?
Old 03-22-19, 11:17 AM
daddystop
daddystop's Avatar
I'd venture to guess it will work on most any vehicle 1995+.
austex300
RX - 1st Gen (1999-2003)
13
07-08-13 06:56 PM
inkredible
Performance & Maintenance
04-08-13 02:10 PM
qewani1
09-10-10 03:03 PM
grindin8o8
05-17-10 07:45 PM
Quick Reply: Accelerator pedal jerking on its own
