Are Straight Pipes on LS430 Bad for the Car?
Old 03-13-19, 06:46 PM
nbizzle
nbizzle's Avatar
Default Are Straight Pipes on LS430 Bad for the Car?
So let me start with, I completely understand and respect that the Lexus LS430 is a refined luxury machine, engineered largely for it's smooth and quiet style. That being said, I have seen a few videos where people had removed the 3rd catalytic converter and run straight pipes. Not sure if they have mufflers or not.. They sound pretty good! I'm wondering how this effects the engine and computer systems. Any advice on systems such as this?
Thanks
Old 03-13-19, 07:18 PM
911LE
911LE's Avatar
Not bad for the car, just everyone else that has to listen to it.
The following 2 users liked this post by 911LE:
nbizzle (03-13-19), potaijee (03-14-19)
Old 03-14-19, 01:25 AM
BCT
BCT's Avatar
Removing catalytic converter.... I am not a lawyer, but I am pretty sure that is illegal. Also, it is not good for the environment.
Old 03-14-19, 06:07 AM
05ls430518
05ls430518's Avatar
Dont do it your car could possibly get feline aids!!!! Also removing oem emissions equipment is super illegal.
nbizzle (03-14-19)
Old 03-14-19, 08:56 AM
JBrady
JBrady's Avatar
As a test I pulled off everything after the front Y on my 99 and it was LOUD and actually seemed to have lost torque. Of course this shortened the system and created resonance as the outlet was basically in the middle of the car between the road and floorboard. What is your goal?
nbizzle (03-14-19)
Old 03-14-19, 09:05 AM
robbyboy32
robbyboy32's Avatar
A better idea would be to get a few borla resonators, get a harbor freight tail pipe expander, and just replace your mufflers with the borlas
nbizzle (03-14-19)
Old 03-14-19, 09:10 AM
nbizzle
nbizzle's Avatar
So, am I right in assuming this would give me some sound, preserve all factory engineering (other than quiet of course), and not harm anything, other than noise pollution?
Old 03-14-19, 09:16 AM
nbizzle
nbizzle's Avatar
My goal is to get a little bit of a sporty sound and maintain all factory engineering and not harm the car at all. The only reason I discussed the Cat's at all is because I know so little and most of the videos I pulled up involved cars with the 3rd Cat removed. I would MUCH rather not remove anything. Plus to be honest I'm still up in the air about this all together, probably won't do it until I have an exhaust issue that requires something being replaced, and want to 100% be sure this will not affect any of the rest of the operations of the car in a negative way whatsoever.
Old 03-14-19, 09:17 AM
nbizzle
nbizzle's Avatar
Talking
Originally Posted by 05ls430518
dont do it your car could possibly get feline aids!!!! Also removing oem emissions equipment is super illegal.
hahahahaha!
Old 03-14-19, 09:47 AM
kos
kos's Avatar
Don't think removing the final converter will adversely affect anything, seems plenty have done it in the past when doing custom exhausts. I definitely wouldn't straight pipe it, but an X-Pipe and a pair of nice mufflers would probably give you the sound you're after, and not annoy you with drone when cruising on the highway.
nbizzle (03-14-19)
Old 03-14-19, 10:19 PM
cookieend
cookieend's Avatar
Thanks
been thinking about This too wondering is it will hurting the motor with an h pipe and borla mufflers with e cutouts. Was gunna do 2.5 tubbing to replace the mufflers but I want that stick like look to my car
Old 03-15-19, 05:40 AM
Johnhav430
Johnhav430's Avatar
My understanding is that back pressure is needed. Which is why vehicles with true duals (Ford Raptor V6, certain BMWs like mine, blah blah blah) usually have X and H pipes if you look at the system in its entirety. Most vehicles of course have fake duals like our LS430, so could be altering it is fine.
Perhaps the best analogy is when one drives a car with a broken exhaust all the way to the cat. It is actually quieter at a sweet spot (rpm and mph), than it is at idle, as well as WOT.
I have always wondered when and why car cos. put fake duals on. But today? They even have fake outlets!! Look at a brand new Audi Q5 or S5. Or a Toyota Camry with dual tips. That is pretty sad imho, and takes fake duals to another level.
Old 03-15-19, 08:44 AM
BCT
BCT's Avatar
I saw that fake duals on Camry the other day! I could not believe my eyes lmao
Old 03-15-19, 09:46 AM
Ricklin
Ricklin's Avatar
Default Connected
Even two cylinder motorcycles generally have the two connected for the exhaust. A 'balance pipe' is employed that connect the two exhausts together, they then exit as two pipes.
Old 03-16-19, 08:33 AM
Vantage007
Vantage007's Avatar
It's funny, I'm actually having the opposite problem. My car has an aftermarket Magnaflow on it that's barely noticeable and adds a bit of "oomph" at wide open throttle. I just want to go back to stock tips because I'm a #StickWithStock guy, haha.
Quick Reply: Are Straight Pipes on LS430 Bad for the Car?
