Headlight solution
Old 03-12-19, 01:38 PM
chivkea
chivkea's Avatar
Default Headlight solution
Hello, need some advice here. From the below images of my headlights, do the smudges and scratches look like the typical oxidation or from unprofessional car wash chemicals?
Is there any way to remove the smudges? Does toothpaste really work?
Thank
Old 03-12-19, 01:54 PM
Zmon
Zmon's Avatar
Looks like oxidation to me. I would personally have them wetsanded with a couple layers of UV-resistant clear coat applied afterwards.
bakalag (03-12-19)
Old 03-12-19, 03:22 PM
bakalag
bakalag's Avatar
Agree with above, you can also look into clear bra-ing the headlights after they are restored. I did mine restoration but it came back after a year even after applying UV, restored it again and same thing after another year, someone introduced me to Xpel clear bra, restored it again and clear bra'd and hasn't yellowed in 2 years since I had it.
Edit: also, looks like your car does have some sort of clear bra on the fender/hood
Old 03-12-19, 06:14 PM
lockedlex
lockedlex's Avatar
Definitely Oxidation, look at your rubber seal next to the hood... it's deteriorated. The only reason your paint doesn't look equally as bad there is because of the clear bra that looks to be on it. The good news is that it's not that bad. A orbital polisher, some compound and polish, then finishing off with wax will make it look like new!
Old 03-13-19, 08:29 PM
nosurprise
nosurprise's Avatar
They don't look bad enough to wet sand and polish. If you do, prepare to do it once a year afterwards or they will look worst than they do now.
Old 03-14-19, 09:30 AM
LowRida
LowRida's Avatar
Yeah that looks like oxidation, typically headlights start their oxidation process from the top like (at least from my experience).
Old 03-20-19, 08:43 PM
huntmotors
huntmotors's Avatar
Default Cheap Headlight Oxidation Solution
this really works guys tried myself and super cheap you can get everything from the Dollar Store.
Revived
04-06-17 06:24 PM
akanick
09-02-15 12:52 AM
dunnojack
Lighting
01-05-11 10:31 PM
5t341th
12-09-10 09:57 AM
Kromekicks
01-12-09 12:40 PM
Quick Reply: Headlight solution
