LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
2011 LX570 on BFG 275/60R20 K02s
Old 03-09-19, 03:04 PM
11lx570
11lx570's Avatar
Default 2011 LX570 on BFG 275/60R20 K02s
After going through as many of the off-road tire threads as I could, I settled on the 275/60R20 BFG K02s for my 2011 LX570. These are replacing Michelin Latitudes in the stock 285/50R20 size at about 4/32s tread depth remaining. Here is what I can report (just my personal experience).
No rubbing that I could hear or feel on the highway or neighborhood roads during normal driving in any height mode.
Rubbing with the steering wheel turned to the stops as follows:
High height; Wheel turned all the way left:
FL: slight rub on mud flap
FR: clears front wheel well by about a 2cm
High height; Wheel turned all the way right:
FL: clears front wheel well by about 2cm
FR: slight rub on mud flap
Normal height; Wheel turned all the way left:
FL: clears mud flap by about a millimeter
FR: clears front wheel well by about 2cm
Normal height; Wheel turned all the way right:
FL: clears front wheel well by about 1cm
FR: rubs mud flap
Low height; Wheel turned all the way left:
FL: clears mud flap by about a 1mm
FR: clears front wheel well by about an 1.5cm
Low height; Wheel turned all the way right:
FR: rubs mud flap
Picked them up from discount tire, so currently debating returning them for the 275/55R20s (the size they recommended), or deleting the mud flap.
I could not notice a discernible difference in tire noise or ride quality.
Hope this helps. I will upload pics and hope they stay in the order above.
High Mode; Wheel Left; Front Left
High Mode; Wheel Left; Front Right
High Mode; Wheel Right; Front Left
High Mode; Wheel Right; Front Right
Normal Mode; Wheel Left; Front Left
Normal Mode; Wheel Left; Front Right
Normal Mode; Wheel Right; Front Left
Normal Mode; Wheel Right; Front Right
Low Mode: Wheel Left; Front Left
Low Mode; Wheel Left; Front Right
Low Mode; Wheel Right; Front Left
Low Mode; Wheel Right; Front Right
The following 2 users liked this post by 11lx570:
Discount Tire (03-11-19), TraderHal (03-11-19)
Old 03-09-19, 05:44 PM
UCrazyKid
UCrazyKid's Avatar
I’m running 275/55/20 KO2 on factory wheels, I only get rubbing occasionally at full lock in reverse.
Old 03-11-19, 07:11 AM
Discount Tire
Former Sponsor
Discount Tire's Avatar
Thank you for sharing and for choosing Discount Tire, 11lx570!
Another option is to heat up the plastic where the tire rubs with a heat gun and push it inwards. I've also seen guys drill two small holes in the inner fenders, and either wire tie, or zip tie them back.
Old 03-17-19, 12:07 PM
11lx570
11lx570's Avatar
I went with the heat gun option on the inner portion of the front mud flaps. Happy to report that I haven't had any rubbing at any height, wheel position or in reverse. I did some very easy off-roading, and I didn't hear or see any indication of rubbing while navigating through ruts or uneven ground.
Discount Tire (03-18-19)
Old 03-19-19, 08:07 PM
UZ214
UZ214's Avatar
can you take pictures away from the car? how it looks- Thanks!
Old 03-21-19, 10:00 AM
11lx570
11lx570's Avatar
Here you go. Normal mode and high mode.
Normal
High
Discount Tire (03-22-19)
Old 03-21-19, 12:40 PM
hankinid
hankinid's Avatar
It may be just me, but I'd be more interested in how the truck handles...especially in bad weather and / or off-road.
Old 03-21-19, 08:31 PM
UZ214
UZ214's Avatar
looks amazing, the 20s look like 18". I think it should handle better off road;
IS250Vic
Suspension and Brakes
15
09-14-19 11:24 AM
ubaratham
ES - 5th Gen (2007-2012)
07-11-18 09:11 AM
bear2
RX - 3rd Gen (2010-2015)
12-23-10 02:17 PM
MicaISF
IS F (2008-2014)
01-05-10 02:29 PM
Quick Reply: 2011 LX570 on BFG 275/60R20 K02s
