lower ball joint replacement
Old 02-21-19, 07:36 AM
GreggyG
GreggyG's Avatar
Default lower ball joint replacement
I'm not sure if I need one yet, I'm hearing a faint clunk occasionally when I am slowly stopping. Just curious though about the part number, does anyone know it? I can't seem to find it and I'm also curious as to how hard/easy it is to change? We don't need the entire lower control arm do we?
Old 02-21-19, 08:17 AM
vwynn
vwynn's Avatar
http://www.toyota120.com/forum/showthread.php?p=214224
Old 02-21-19, 08:25 AM
IanB2
IanB2's Avatar
Many guys do the entire LCA as the bushings will be worn out as well by the time the LBJ goes. By the time you replace the bushings and LBJ, you're probably further ahead replacing the entire LCA, but they aren't cheap for OEM.
Old 02-21-19, 10:00 AM
GreggyG
GreggyG's Avatar
thank you, I appreciate the help.
Old 02-21-19, 12:05 PM
campfire
campfire's Avatar
I did them on my 4runner last fall. I used a sawzall to cut the old ones off and bought new bolts from the dealer.
Old 02-22-19, 03:48 PM
chiph9
chiph9's Avatar
Have you looked at your driveshaft yet? There's a TSB and improved part that corrects a clunk when stopping. About $700 at the dealer (parts + labor).
Chip H.
Old 02-23-19, 12:40 PM
NTH
NTH's Avatar
Great advice!
Old 02-23-19, 01:48 PM
campfire
campfire's Avatar
these are hard to beat for the $. https://www.ebay.com/itm/New-Front-L...99:rk:190:pf:0
Old 02-24-19, 04:58 PM
GreggyG
GreggyG's Avatar
I have KDSS by the way, and my driveshaft had the TSB done before I got it, and I keep up with greasing the yoke. I think it may be related to my KDSS sway bar in the vertical hydraulic shaft. I'm not 100% sure.
Old 02-27-19, 07:18 AM
maxx430
maxx430's Avatar
I have KDSS as well and did my LCA this past weekend. Something to keep in mine. Lexus/Toyota in USA does not sell OEM LBJ separately, but they do sell the complete KDSS LCA for about $400+ each side (not the route i went). I purchased the OEM LBJ from ebay for about $110 a pair, part number 43340-60020 and all four OEM LCA bushings for about $130. One of my LBJ was opened and was puncture in the rubber so i am working with the selling to get partial refund. As for the punctured LBJ, i replaced it with a great aftermarket unit branded 555 Sankei, which is known to be OEM or equivalent and has been widely recommended with the off-road community, GXOR/ih8mud. Stay away from Moog.
side note- i too was getting clunking noise but that was only when i took off from a dead stop. If i accelerate slowly, i dont get the clunk which sounds like its coming from the driver side wheel. I assumed it was my LCA case thats the only thing that was not replaced in that region. I replaced the tie rod, rebooted my OEM axle, installed ICON shocks and springs, installed SPC UCA. Clunk still there....maybe something is loose??
Old 03-02-19, 07:12 AM
GreggyG
GreggyG's Avatar
Thank for the info
Old 03-02-19, 05:56 PM
GreggyG
GreggyG's Avatar
what did you do to gain access to that area? took off the two 19mm bolts to separate the lower control arm from the knuckle/axle, remove the ball joint spindle bolt thing, then what did you do to gain access to the ball joint, disconnect the outer tie rods and then swing the assembly over to the side some?
Old 03-04-19, 10:03 AM
maxx430
maxx430's Avatar
The entire LCA was removed to gain access to the ball joint and bushings.
Nguyen07
Suspension and Brakes
02-13-14 08:06 PM
SC3coupe
08-06-13 02:33 PM
rwdanthony
06-10-10 07:42 PM
SCSpeed
11-19-07 10:08 PM
dale88
09-26-03 08:07 AM
Quick Reply: lower ball joint replacement
