IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS200 cruise control
Old 02-17-19, 01:37 AM
auriakas
auriakas's Avatar
Default IS200 cruise control
Recently i swaped my automatic transmission in IS200 to a manual one and after that cruise control stoped working. Is there a way to make it work again?
Old 02-17-19, 07:33 AM
Nad1370
Nad1370's Avatar
This might make sense.
PRNDL switch might need to be on the "D" position for the cruise to set.
If you swapped it out with a manual, you mustve needed to set the PRNDL switch to either "P" or "N" for you to start the car.
Old 02-17-19, 07:39 AM
auriakas
auriakas's Avatar
I've done it by a tutorial and conected 2 wires near transmision for the car to start. Currently the car is still running on manual ECU, but i've still got the A/T one. Maybe there is another way to bypass the "D" position?
Old 02-17-19, 07:55 AM
Nad1370
Nad1370's Avatar
ECU needs to see its in "D" position to set cruise. (if its an automatic vehicle (ECU) )
Thats what probably happening.
The tutorial is probably jumping wires to see neutral or park to be able to start the car.
Manual IS200 didnt come with Cruise control
Cruise control is operated by the ECM.
If you have a manual ECM, cruise is non-existent.
Old 02-17-19, 08:12 AM
auriakas
auriakas's Avatar
Basicaly ECU is responsible for CC, I was thinking that there was a different module for CC. Thanks for help.
TRANC3
RC F (2015-present)
06-17-21 07:07 AM
Boger
RX - 1st Gen (1999-2003)
20
05-24-16 10:48 AM
JDMV8
IS F (2008-2014)
08-07-12 09:02 PM
diablo1
11-27-05 07:23 AM
Quick Reply: IS200 cruise control
