2013 rx 350 window lock and window issue
I'm helping a friend troubleshoot their car. The driver's side has a window lock button, the LED/light isn't lighting up, the button doesn't do anything when engaged, meaning, lock the other windows. The driver window only goes up and down, it can't be stopped in the middle. The other windows work fine when testing individually at the respective door.
I have not seen the car, yet, this is what I have been told. I don't own an RX, is there a fuse that controls the driver side module? I'd assume if there was, then it would apply to the entire module and not just part of it.
Based on what I have been told, it seems that the module is bad and needs to be replaced, but I figured I'd ask here, first. (I had an account at my.is, but I guess that site is no longer active).
Thanks!
edit- While trying to research this forum and other links from google search results, it seems that this is common after a dead battery/battery disconnect. Not sure if that ever happened, I'll will ask.
Thanks!
I bet the switch is bad. Since the window moves it is not a fuse issue.
You can get a replacement used master window switch for around $40 on eBay. They are the same for all 2010-2015 RX350 and RX450h models. Note there are wood grain variations so make sure it matches what is in the vehicle. Replacement should be the same as any other Toyota/Lexus. Youtube probably has an instructional video.
update- Mirror controls and door unlock/lock does not work, either. Fuse in the engine bay shows 12v. Looks like the driver door module is bad.
edit- Fuses on the driver side, under dash, are good, as well.
A replacement driver side module was purchased from ebay (all the switches, mirror lock, mirror adjustment, etc...) it arrived, I swapped it out with the one in the car and the issue is not resolved. I highly doubt the part from ebay had the same issue as the existing part in the car.
To be clear, the only thing that works is the driver window goes up and down from the driver control. It doesn't go up or down on its own, the button needs to be continually pressed/held down/up. The automatic mirror fold button doesn't work, neither does the mirror adjust or the window lock. Also, none of the windows can be controlled from the driver side controls.
All the fuses that I checked tested good (I checked all of them).
edit- I'm not sure what normal window operation is like, but I noticed when the window button is held down or held up, it flashes 3 or 4 times before it turns off. The flash I'm referring to is the small LED bar under the window switch.
You seem like you have a blown fuse.
I know you mentioned checking all fuses.
Please check the 7.5amp ECU-B NO.2 fuse under the hood junction block.
Dont just pull out the fuse but check if you actually have power to it.
Let me know what you find.
I will check that one, again (in a few moments), I will check any other fuse, again, if someone has a specific fuse to check. When I checked the fuses, I touched the metal opening on the top of each fuse and looked at my meter to check there was 12v.
Thanks.
Fuse is good, showing 12v on each metal opening at the top of the fuse and I pulled the fuse to check continuity, which was assumed good due to seeing 12v, but I confirmed, fuse is good. When I pulled the fuse I was no longer able to control the driver window up/down, when I put the fuse back in, I still had the same problem, but power was restored to the window.
Thanks.
Thanks.
Do you have illumination lights on the MASTER switch?
Each window control switch in the MASTER switch should have an LED light lit up with key ON.
Let me know if you have these lights and note if they are on or blinking.
Try your orig master and your ebay one.
See if there are any differences.
Now we check power and ground in the master switch on the drivers side.
We probably know we have it but i just want to make sure since the side mirrors and door locks share the same ground.
--- Pop the master switch out.
--- Disconnect the connector. (should be a 20 pin connector)
--- Key ON position
--- Locate the WHITE with a BLACK tracer wire --- see if you have continuity to ground.
--- Locate the LIGHT BLUE wire (should be right next to it) -- see if you have 12v power.
If you have both of these, then you have a bad MASTER switch.
dtlexowner (02-18-19)
Thank you for confirming that.
--- Key ON position
--- Key ON position
To be clear, the master switch is the entire module that pops out of the door panel, correct? The master switch is not something that is located inside the module, correct? I'd like to confirm we are talking about the same thing.
Thanks for your help.
Did you try initializing each window?
Im not sure on how to do this step.
You might need to initialize each window from its own door switch.
Try this as well on top of the power and ground checks.
Usually a blinking switch light indicates a non initialized window.
But that still doesnt explain the side mirrors and door locks not working.
That is correct.
Thanks.
--- Key ON position
--- Key ON position
Each window control switch in the MASTER switch should have an LED light lit up with key ON. The only window control switch with an LED light is the driver switch, the other 3 do NOT have an LED illuminated. Also, the driver LED does flash when pressed up or down. After a few flashes it goes back to fully illuminated.
White wire with Black tracer appears to have continuity. I touched the pin with one lead and a bolt on the frame with the other lead and I heard the meter beep.
Light Blue (looks more like teal/light green, to me) I could NOT see 12v on that pin. I tested the Dark Blue with Gray tracer and that one DID have 12v. I went back to the Light Blue wire and attempted many times to try to get good contact, but I never saw any voltage. When going back to the Dark Blue with Gray tracer, very easily I can touch the pin and see a voltage, no re-positioning with the lead was needed.
Thanks.
Thanks for the checks.
Light Blue wire should be next to the White/Black ground wire (left of it on the bottom corner) you just checked.
What wire is there if its not a Light Blue?
Can you take a pic of the back side of the connector and post it?
Sure, I can take a pic, but I do believe we are talking about the same wire. Standby for pic.
