check engine VSC lights on
Old 02-08-19, 06:10 AM
gshort
gshort's Avatar
Default check engine VSC lights on
2005 Lexus GX -- My check engine and VSC lights came on this morn. I fiddled with the gas cap. No luck. I know the gas cap is usually the culprit and first thing to check. But my gas cap is only 4 months old. Is there a way to identify if it is in fact the gas cap? Other than replacing it? I'm in upstate NY and cold/warm weather on and off and wonder if that could damage the cap?
Should i suck it up and just replace it to see?
Old 02-08-19, 08:20 AM
Nad1370
Nad1370's Avatar
Dont replace anything yet.
First find out what code(s) you have.
If you dont have a scanner, Autozone can check your codes for free.
Old 02-08-19, 08:50 AM
gshort
gshort's Avatar
I received P1442 - Secondary Air Injection System Switching Valve No 2 Bank 1 stuck closed Dohhh Any suggestions?
Old 02-08-19, 09:57 AM
gshort
gshort's Avatar
I checked all the vsv hoses and didn't see any lose or damaged. I realize it could be the VSV vacuum switching valve or air injection control circuit or even the ECM... but wanted to try the easy things before I brought it into Lexus and have $2k bill.
Old 02-08-19, 10:23 AM
Nad1370
Nad1370's Avatar
Thats awesome you were able to check them.
Most likely its a stuck AIC valve.
Known problem for these.
Ive seen kits here for that problem but i personally have no experience with those.
Old 02-08-19, 11:37 AM
gshort
gshort's Avatar
yeah i read something about a kit, but did't see the part # or anything. Anyone have a URL or name of the kit?
Old 02-08-19, 01:19 PM
gwebster
gwebster's Avatar
https://hewitt-tech.com/store/index....yABEgJRb_D_BwE
This is the kit I have for my 08 GX470 from Hewitt Tech. Easy to install.
Old 02-10-19, 05:31 AM
burny
burny's Avatar
That there is a sweet device
Old 02-15-19, 07:00 PM
campfire
campfire's Avatar
thanks, I just bookmarked Hewitt for miles down the road!
babyduke
ES - 5th Gen (2007-2012)
07-14-21 01:02 PM
daryll40
02-05-16 06:39 AM
kalali
RX - 1st Gen (1999-2003)
13
10-30-10 02:29 PM
larryhorne
03-28-10 12:05 PM
GrdnRxR
12-22-04 01:59 PM
Quick Reply: check engine VSC lights on
