2015 GS350 F-Sport Nebula Grey Pearl / Cabernet Simple Build
I recently picked up this 2015 GS350 F-Sport AWD in Nebula Grey Pearl with the Cabernet interior. It was a CPO with 33K miles. I’m going to be doing a few simple mods that I thought I would document here. First up... stock photos and “big red bow” delivery shot.
GTGS350F (01-25-20)
AppleTV
First mod - AppleTV is up and running on the main screen! Once I receive the DVD in Motion / Nav Unlock cable from Beat-sonic, I will be able to mirror my phone to it while moving. I should have that done this weekend.
I can go into the details of my signal chain and the products I used to do this if anyone is interested - just let me know. The quality is actually better than I expected going from HDMI to composite. Not bad at all!
USMC84 (06-01-20)
USMC84 (06-01-20)
The GS already as the input for video (albeit analog video) “built in” in the center console in the aux port. So, you have to get the digital signal from the AppleTV converted to an analog signal that the car can use. Here is how I did it...
For powering the AppleTV, I used an old power inverter I had that plugs into the 12 volt power outlet and converts power into 110 volt. The AppleTV doesn’t use much power, so probably almost any power inverter will work. The AppleTV is connected by a short (1ft) HDMI cable I got from Amazon:
...which connects to an HDMI to Composite video converter. There are a bunch of options here, but I got this one since it had good reviews and seemed to be of decent quality:
The included USB power cable just plugs into one of the open USB ports in the console for power.
Then, you need a good A/V cable that connects RCA inputs to a 3.5mm jack. I ordered this discontinued Zune video cable since it was cheap and looked to be of great quality (it is).
That completes the signal chain to have the AppleTV functional in the car. To get the internet to it and have the ability to mirror from your phone, you have to connect the AppleTV to your phone’s hotspot, which essentially creates a Wifi network that connects them together. The AppleTV will automatically connect when you start the car as long as the hotspot is on. Once connected, you will see the AppleTV as an option for Airplay/mirroring from your device and in any app that supports it.
At this point, everything works and is functional, but it won’t allow the video to show while you are moving.
The last step is to get the “Beat-Sonic NDS6223EP Navigation and DVD Control Bypass Module”, which allows the video to work while you’re in motion, and also allows for navigation input while in motion. My cable from beat sonic should arrive tomorrow, and I plan to install and have it running by the weekend. I know there are other options for video in motion bypass harnesses, but their’s seems to be one of the best reviewed, they provide great customer support, and they offer special pricing for club Lexus members. You can send them a DM @beatsonic here in the forums, and they will get you set up - provide you model Year as the module is slightly different for 2015+.
I will update once I get the bypass module installed and everything working. Hopefully that all makes sense, but let me know if there are any other questions I can answer.
Mediabridge Flex Series HDMI Cable (1 Foot) Supports 4K@50/60Hz, High Speed, Hand-Tested, HDMI 2.0 Ready - UHD, 18Gbps, Audio Return Channel
HDMI to 3RCA Composite AV Converter
Zune A/V Output Cable
USMC84 (06-01-20)
this is great thanks! Can I completely skip the Apple TV and connect directly to the iPhone ? I primarily want to use this setup for navigation, audio, apps etc but don’t see the value of using Apple TV just for mirroring the phone. Also I can not clear on what you mean when you say that the video will stop when the car is moving. Additionally will the RCA cables carry both sound and video?
Apple Lightning to Digital AV Adapter
Then, you can just plug the HDMI cable straight into the adapter (which plugs into your phone) instead of the AppleTV. Mirroring and video output will work the same way as it would through the AppleTV.
The RCA cables do carry both audio and video. What I mean by the video not working when the car is moving is exactly that. Without modification, the car will not allow video to play on-screen unless the car is in Park. The A/V input source changes to a blue screen when you take it out of “Park.” The DVD player does the same thing. That’s where the Beat-Sonic module comes in - it enables the video to play while in motion.
USMC84 (06-01-20)
Absolutely. I wanted the AppleTV so I could do it wirelessly as well as use the native apps for content. If you don’t need that, you can just use the Apple lightning to HDMI adapter:
USMC84 (06-01-20)
USMC84 (06-01-20)
I have all the parts and have been mulling over doing this for the past 3 months; how is the experience?
USMC84 (06-01-20)
Note that For controlling the AppleTV (not mirroring) via the IR remote, I just slide the center armrest back a bit and point the remote at the center stack. It bounces off of there and hits the AppleTV, which sits on the tray under the armrest. It would be even easier if you use a newer 4K AppleTV, since the control is Bluetooth, or you can also use the Apple remote app on the phone which also works wirelessly over WiFi. Overall, it works extremely well and definitely worth the relatively minimal expense and effort.
That apple tv pairing sounds crazy, still don't fully understand how you would do that through the screen. Do you navigate and access everything through your phone or are you able to use the mouse on GS to select what you want to do.
I use the AppleTV remote to navigate - you can’t use the Lexus “mouse” unfortunately. I got the Beat-Sonic module installed and it’s very slick... I drove around today with my kids and they were watching The Grand Tour on the Amazon Prime app on The AppleTV. I didn’t have to mess with my phone at all.
I had some time last night and today to work on the car and did a few more things.
1. Installed LEDs in all the turn signals, trunk dome light, and reverse lights. Inexpensive and so much brighter and crisper.
2. Installed 20mm spacers all around. I love this one - changes the stance and overall appearance so much having the wheels flush with the fenders. It just looks so much more aggressive.
3. Blacked out the chrome front grill with Plastidip. I’ll be doing the door surrounds and back piece soon - I just didn’t have the time.
4. Installed “Skipper” style front lip from eBay. For $65, it’s pretty sweet...
I also got the supplies to paint the brake calipers. Waiting on decals to come in and a few hours of time, and I will get them done.
The car also goes in tomorrow for 20% tint. Here are a few pics of the work done to this point. Sorry the car is a bit dirty... I will post some more after tinting...
GTGS350F (01-25-20)
Does it ride/handle any different with the spacers? Are you going to do anything with the AWD ride height or leave it?
