Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
caliper sticking occasionally? Piston?
Old 01-22-19, 01:26 PM
daddiojigg
daddiojigg's Avatar
Default caliper sticking occasionally? Piston?
I had a grinding noise the other week and couldn't get to it for a couple of days. Noise seemed to be coming from rear drivers' side. Turns out that i was practically on the rivets of left rear brake pad. Both of the pads down to the rivets. Passenger side was like brand new. Changed out pads ( both sides) and of course noise was gone. Now it may be my imagination BUT , from time to time, i swear i hear a little drag on the L/S. One day i decided to feel the rotors after stopping and L/S was warmer than R/S. when i changed the pads i was careful to clean out cavity that slide pins go into and greased up pins while being careful not to overdo them.I should also state that i changed out R/S caliper two years ago as it was seized. At that time i bled both sides (yes,with techstream) and last year i bled both sides again after changing rear hubs/bearings and had good flow. What would cause the caliper piston to stick occasionally? Has anyone had similar experiences and what was the solution? Thanks
Old 01-22-19, 02:14 PM
Nad1370
Nad1370's Avatar
If you already cleaned out the slides and the bracket where the pads sits. (pads should also more freely here)
L/R caliper piston is most likely the culprit.
Piston probably has some rust build up thats dragging on the caliper cylinder.
Might've gotten moisture which rusts up in there if the piston boot has a tear over time.
There might be rebuild kits out there, but id just replace them like you did on the other side.
daddiojigg (01-22-19)
Old 01-22-19, 02:37 PM
mnewxcv
mnewxcv's Avatar
I've had caliper issues on several vehicles: 1998 Ford Contour, 2000 Jeep Cherokee, 1995 Lexus SC300, 2003 Honda Odyssey, etc. Caliper pistons just seem to fail after a while. I would say that is a sign that it is on it's way out, especially given the extreme wear on the previous pads.
Old 07-09-19, 04:59 AM
daddiojigg
daddiojigg's Avatar
Angry Update
well, almost 6 months to the day and the problem has come back. Cleaned all slides and pins initially and just yesterday it started again. Comes and goes but ALWAYS occurs( grinding sound) when i am in a turn and pressure is put on l/s rear axle. SOMETIMES going over a bump straight will initiate the noise but it doesn't last more that a few seconds. Usually putting on and putting off brake pedal will cause grinding noise to go away which makes me think caliper piston is sticking occasionally. Last time i squeezed piston back into caliper with ease which lead me to believe that piston/caliper was fine but now, six months later? same? Going to have to get into it later today but hoping i don't have to replace caliper and all that bleeding BS.
Old 07-09-19, 03:02 PM
ukrkoz
ukrkoz's Avatar
Brake pads do not make grinding noise, unless they are worn out. Caliper piston is not touching rotor surface to produce grinding noise, unless pad is worn out. So you need to check pads first. If they are good - look place else for noise source. Like half axle. Bent dust shield.
Old 07-09-19, 04:32 PM
mnewxcv
mnewxcv's Avatar
Good pads can still make noise, especially if the rotor was not resurfaced and had some grooves.
Old 07-10-19, 05:10 AM
daddiojigg
daddiojigg's Avatar
I never resurface rotors. Always put new ones on if needed. Dust shield-- ripped it off two years ago when i was doing my hubs, rusted right out.
Got into it yesterday: pads were toast on L/S . R/s was fine. Suspected caliper or piston and so i replaced the caliper. Used Snap-On 'techstream' to bleed and clear all codes. Everything is good-- for now.
mnewxcv (07-10-19)
Old 07-10-19, 08:30 AM
mnewxcv
mnewxcv's Avatar
no such think as a coincidence. Caliper was likely bad; there are few things that would do what you describe other than the caliper. I also have a left side rear drag and did my pads a few months ago. Hoping it doesn't happen again (though, I used an infrared therometer to check rotor temps after driving and it matches the right, so I suspect no more drag, that the slide pins were causing the issue in my case).
Old 07-10-19, 03:22 PM
daddiojigg
daddiojigg's Avatar
"that the slide pins were causing the issue in my case" . I don't know how you did your pins , so i'll tell you how i did mine:
After pulling out the pins i put them on a wire wheel to clean them up -threads and all. Be careful with the grommet or ring on the one pin. I then get a small drill bit sized brush that fits onto a drill and spray inside the hole with a degreaser where pins go and then 'ream' the hole GENTLY to get old lube out.
I had done all this in preparation for my new calipers arrival. Well, doesn't the caliper come with a new bracket and new pins as well, so cleaning and lubing was for naught!
Old 07-11-19, 01:36 AM
mnewxcv
mnewxcv's Avatar
Ha, yes it's nice when the caliper comes with the bracket so you literally are reusing nothing from the old one. My pins were a little rough looking but I just sanded them by hand and threw in some fresh grease. I think I used the purple ceramic brake caliper lube. It's been about 6k miles since and I haven't noticed any issues yet recurring.
Old 07-11-19, 06:59 AM
thomas1
thomas1's Avatar
You might want to replace the flexible brake line going to that caliper, A friend had same problem on his Chevy Truck, did all the same stuff you did, but the culprit was the rubber brake line had swollen inside and was restricking fluid from releasing on the caliper. Replaced line and never had a further problem.
The following 2 users liked this post by thomas1:
Chapp (05-31-21), daddiojigg (07-11-19)
Old 07-11-19, 07:46 AM
mnewxcv
mnewxcv's Avatar
That is the most likely culprit after the caliper. The Toyota lines are usually pretty reliable though depending on region. Like you said, it's like a pinched straw the brake fluid gets pushed through under force, but can not go back through without force and therefore holds the piston in. Should be easy enough to know if the problem remains with a new caliper though.
Old 07-11-19, 03:30 PM
daddiojigg
daddiojigg's Avatar
Good to know but i wish you had said this two days ago. Still, something to keep in mind for later. That really would explain a few things. Never heard of that before, though. Thanks!
ihiryu
Suspension and Brakes
08-06-12 10:13 PM
RXGS
14
03-25-12 11:12 PM
truenoboy
21
07-20-10 03:19 PM
masitaly17
12
08-21-08 10:46 PM
Stage3
06-23-08 05:01 PM
Quick Reply: caliper sticking occasionally? Piston?
