What transmission fluid is needed?
Old 01-13-19, 04:15 PM
Sin1UZFE
Sin1UZFE's Avatar
Default What transmission fluid is needed?
For aa99 ls400?
I lost the PDF manual for it.
Old 01-13-19, 05:40 PM
Fit1too
Fit1too's Avatar
This is the fluid I used:
Amazon Amazon
The 12 pack is even cheaper, but I wanted to show the actual bottle.
This site has the manual: https://drivers.lexus.com/lexusdrivers/
Old 01-14-19, 10:50 AM
Sin1UZFE
Sin1UZFE's Avatar
looks wrong?
Old 01-14-19, 11:07 AM
Fit1too
Fit1too's Avatar
When I got my car I noticed that the previous owner had taken it to an independent garage and had a transmission fluid change. They used some off brand fluid, and on top of that they added some bull**** called BG A/T Conditioner. I immediately ordered a case of T IV from Amazon and over a period of 3 days I changed out 12 quarts (drain, refill, drive 30 miles, drain, refill, etc). I plan on doing it again this spring when the weather warms up. My fluid looks way better than when I got the car and it shifts beautifully!
Old 01-14-19, 11:09 AM
Sin1UZFE
Sin1UZFE's Avatar
Originally Posted by Fit1too
When I got my car I noticed that the previous owner had taken it to an independent garage and had a transmission fluid change. They used some off brand fluid, and on top of that they added some bull**** called BG A/T Conditioner. I ordered a case of T IV from Amazon and over a period of 3 days I changed out 12 quarts (drain, refill, drive 30 miles, drain, refill, etc). I plan on doing it again this spring when the weather warms up. My fluid looks way better than when I got the car and it shifts beautifully!
So take this mess out and use what was linked above? 12qt damn!
Old 01-15-19, 04:44 PM
timmy0tool
timmy0tool's Avatar
I swear by Toyota T-IV ATF only, and lots of folks here will agree.
12 qt is only for a "flush" over the course of a few days as fit1too stated.
most driveway mechanics don't have the complicated fluid transfer system so we are forced to do drain/fills over time manually.
a drain of the pan will only remove the fluid in the pan, where about 80% of the fluid is still inside the system such as the valve body, torque converter, cooler, etc.
you have to do drain then fill and repeat to get most of the fluid cycled out.
it took me 12 qts to remove and replace the ATF, and I'm certain I still did not get all the old fluid out but at least most of it.
by the way you don't have to drive the car to flush (I didn't but it helps).
I just disconnected one of the ATF lines running to the radiator and drained about a quart of fluid by running the engine which pumps the fluid through.
shutting off the engine stops the flow, then add equal amounts of new ATF that was removed through the dipstick, and repeat until ATF is transparent red (or in my case until I ran out of new ATF).
Old 01-15-19, 04:56 PM
RA40
RA40's Avatar
Cycling the fluid out like Timmy mentions is If draining from the pan in multiple sessions use the fiber washers instead of the aluminum crush type. That way you won't be getting such short use between drains on the washer. Lexus charges $1.25-$2.50 for them. Toyota was $.75 but a pack at the auto parts store in the correct ID-OD size is way less.
Old 01-15-19, 04:58 PM
Sin1UZFE
Sin1UZFE's Avatar
Thanks guys!
Old 01-15-19, 07:37 PM
Losiracer2
Losiracer2's Avatar
will the plug leak if I didn't use a washer on my last drain/fill? when I removed the drain plug, I didn't see one on there.
Old 01-15-19, 10:08 PM
RA40
RA40's Avatar
Probably stuck to the pan or bolt. The aluminum is reasonably soft and even when squished it seals within reason. Torque it enough times and it will begin to leak. If one doens't torque it to much just when it begins to compress that's usually sufficient for a good seal. That way I get 2 uses from it. I've gone to using the fiber or synthetic type which has been much less of a worry with leakage.
Old 01-16-19, 08:45 AM
Fit1too
Fit1too's Avatar
Hey guy, just a heads up. The link I provided earlier was for a 6 pack. I used it because it actually showed what a single bottle looked like. Here is the link for the 12 pack
Amazon Amazon
Old 01-16-19, 01:11 PM
Sin1UZFE
Sin1UZFE's Avatar
Hey guy, just a heads up. The link I provided earlier was for a 6 pack. I used it because it actually showed what a single bottle looked like. Here is the link for the 12 pack https://www.amazon.com/Genuine-Toyot...rds=toyota+tiv
thanks.......
argonfatl
Hybrid Technology
15
08-29-22 10:33 PM
shroomysou
31
12-24-19 04:04 AM
350rx
10-30-19 08:04 PM
ALLCHILL
12-09-14 02:50 PM
ISFer
IS F (2008-2014)
14
04-27-10 11:56 AM
Quick Reply: What transmission fluid is needed?
