Timbren installation videos
Old 01-11-19, 01:49 PM
Acrad
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
Lightbulb Timbren installation videos
_https://www.youtube.com/watch?v=DKoxf7m67es
Old 01-11-19, 01:50 PM
Acrad
Acrad's Avatar
_https://www.youtube.com/watch?v=cmG4WMqqW-8
Stock rear bump stop replacement
Old 01-11-19, 03:57 PM
Acrad
Acrad's Avatar
I'm not running anything on the front right now (bumper, winch, etc) so decided to see what these do on the rear since I tow.
I figure if nothing else might be a good failsafe if I lose a bag at a bad time... and could resell at a discount as version is used on many different Toyota models including the Sequoia
Old 01-12-19, 11:43 AM
Greenbow
Greenbow's Avatar
Thanks for posting this. I've got the Timbren's as part of my suspension list and these videos just go to prove the capability of the product.
Old 01-21-19, 03:57 PM
Acrad
Acrad's Avatar
Looks like they arrived while I was out of town. Might install next weekend with oil change and zerk session. I don't plan to do a lift on mine anytime soon but in case the Budbuilt weigh down the front too much I might put the front ones on. We'll see.... might be unnecessary.
Old 01-22-19, 10:06 AM
bambam2
bambam2's Avatar
I'm considering a rear set because I tow about once a month. They seem a little pricey for what they are but they have good reviews on the website.
Old 01-22-19, 02:48 PM
Acrad
Acrad's Avatar
Just an FYI. They come disassembled in the box.
http://timbren.com/blog/products-page/torseq/
Install Instructions from box
http://timbren.wpengine.netdna-cdn.c.../09/TORSEQ.pdf
Not seeing any bolt torque specs. I need to look into FSM and also see if Timbren has a recommendation for at least the center bolt.
Old 01-22-19, 02:53 PM
Acrad
Acrad's Avatar
Here is someone with a '11 460 with them installed
https://www.etrailer.com/Vehicle-Sus...id=20121013627
Old 01-22-19, 04:29 PM
konc3pt
konc3pt's Avatar
Location: From Oakland to Sactown, the Bay Area & backdown
good stuff, what's the cost ?
Old 01-22-19, 04:37 PM
Acrad
Acrad's Avatar
Not cheap but they do have a lifetime warranty. I think once I know how real world they work I can say more. Some of this is a personal experiment. Multiple vendors out there so someone may find a cheaper option. Etrailer info below for 10-19
Rears are $214.67 + sales tax if your state has that
[Front]
https://www.etrailer.com/Vehicle-Sus...id=20181013613
[Rear]
https://www.etrailer.com/Vehicle-Sus...id=20181013627
Old 01-22-19, 10:20 PM
caesosa
caesosa's Avatar
This may sound crazy but I’m wondering if these will fix my “slight” lean issue. According to Lexus only 10mm (20mm is out of spec), but once I saw it lean once I can’t unsee it.
Do they always support the axle or are they clear when there is no pressure from a trailer?
Old 01-23-19, 05:40 AM
Acrad
Acrad's Avatar
I believe front has contact all the time and rear there is some space while level.
Old 01-23-19, 03:51 PM
Acrad
Acrad's Avatar
Inside the Timbren there is a washer already present. Last night put together and lots of play with a washer that would be ringing all the time as it doesn't tighten down. I sent this video to Timbren and they first claimed not tightened enough and then a few minutes later a support message that it was normal. Saw others post they had to put additional washers in it. Doesn't feel right with the current slop. I suppose one could use a tap and die to force the threads further in as there is room inside the metal assembly at top. As-is won't thread on either one into the hollow space at the top.
https://photos.app.goo.gl/r9kK93wxXjNaSftG6
Old 01-24-19, 06:18 PM
konc3pt
konc3pt's Avatar
[Front]
[Rear]
DAMN, feel like 100 bux would've been alright for this,
Old 01-24-19, 06:20 PM
konc3pt
konc3pt's Avatar
sounds like oversight on the engineering, are you gonna stick with it or return it ? at premium price this should be nothing short of perfect fit imo
Quick Reply: Timbren installation videos
