Cabin light killed the battery
Old 12-16-18, 07:54 AM
mgs1995
mgs1995's Avatar
Default Cabin light killed the battery
Hey all, I had an unpleasant surprise this week. My son had left the overhead light above his seat turned on Monday evening. On Friday evening (it's a third vehicle so it doesn't get driven every day) I found the GX was completely dead. I took the battery out and recharged it overnight and it seems to be ok. I was really surprised that the GX doesn't automatically turn off the interior lights after a while. My other Toyotas (Sienna and Camry) do. I guess I'll have to be more vigilant on this vehicle. Is there a setting in Techstream that addresses this or is it just a missing feature?
mgs1995 is offline
Old 12-17-18, 05:30 AM
hzhao
hzhao's Avatar
Mine does. If the lights were left on, it shuts off after maybe 15 mins or so. Mine was 2014 GX.
hzhao is offline
Old 12-17-18, 07:36 AM
GoHuskers
GoHuskers's Avatar
mine 2015 does turn off lights my itself after a short time too. I have a 3 years old and he likes to push these switches.
GoHuskers is offline
Old 12-17-18, 08:14 AM
craigrpete
craigrpete's Avatar
I don’t think my 2012 Base overhead lights shutoff automatically but I’d have to verify. I know once we left s light on at an airport parking garage and battery was dead when we got back a week later.
craigrpete is offline
Old 12-17-18, 08:17 AM
Statman
Statman's Avatar
2015 shuts off automatically
Statman is offline
Old 12-17-18, 09:50 AM
Acrad
Acrad's Avatar
Received 3,563 Likes on 2,333 Posts
Never tested but my '12 owner's manual says this. Could main switch have been in the OFF position? This may override the timer.
Acrad is offline
Old 12-17-18, 10:10 AM
bbqsoup
bbqsoup's Avatar
If you haven’t yet, you can change the interior bulbs to LEDs to help with less current draw if left on.
bbqsoup is offline
Old 12-17-18, 01:16 PM
pinoyesv6
pinoyesv6's Avatar
I defintely agree with this. I've built LED arrays for all of my cars since I started driving. The LEDs have definitely saved me from going meeting a dead battery caused by the cabin light, on more than one occasion.
pinoyesv6 is offline
Old 12-17-18, 03:09 PM
Craigyyy
Craigyyy's Avatar
Are you sure the light stayed on?
Could it be that it was just time for a new battery?
I just replaced my battery in my 2011 about a month ago.
Craigyyy is offline
Old 12-17-18, 03:30 PM
mgs1995
mgs1995's Avatar
Pretty sure. The battery is less than a year old and it recharged ok. It’s been ok since.
By the way, it’s a 2012 base.
mgs1995 is offline
Old 12-18-18, 11:41 AM
bd5400
bd5400's Avatar
For what its worth, my 2011 does not turn the lights off automatically but I also keep my door switch to "off", if that matters. I had a neighbor call me once to tell me that my interior light was on. Unfortunately I was 1000 miles away from home....
bd5400 is offline
Old 12-18-18, 02:18 PM
Acrad
Acrad's Avatar
Just ran a test.
Light didn't turn off at 20 minutes... I should have read manual closer on my '12.
Door would have to be ajar as well.
Acrad is offline
Old 12-18-18, 06:00 PM
tecman
tecman's Avatar
I have not looked into it but the headlights stay on for more than what I set it to (Max that I think was 30 seconds) after exiting the truck and open another door.
So here is an example that I experienced today, I pull into my garage which is dark enough to turn on the headlights, I open a second row door and unload some groceries and close the door 2-3 minutes later with headlights still on. I open the rear window within 30 seconds to retrieve the rest and the headlights remain on until I close the window and then headlights turn of in the usual time.
tecman is offline
Old 12-18-18, 06:58 PM
hzhao
hzhao's Avatar
That is correct. According the manual, the lights off timer counts from the point where all the doors are closed AFTER IGNITION OFF AND FIRST DOOR OPENED. So, if you opened any door before the 30 seconds, the counts restarts after all doors closed again. It is also true, if you turned off ignition, but sit in driver seat and never opened door, the headlights will not turned off regardless the off-timer.
hzhao is offline
tecman (12-18-18)
Old 12-18-18, 07:36 PM
tecman
tecman's Avatar
Thanks hzhao, this is a concern if I possibly did not fully close a door or rear window so I go back to my garage to verify the shut off. Automatic shut off would be nice.
tecman is offline
Quick Reply: Cabin light killed the battery
