Options for Splash Guards
It doesn't appear Lexus has OEM mud guards yet. I also checked Weathertech and they don't have ones that fit. Thoughts on other options? Thanks in advance.
I saw them on eBay as well. Do you have to remove the wheels to install though? I also hate the thought of drilling holes into a brand new car
I did not remove any wheels. The fronts matched perfectly to the existing screw holes so no drilling necessary. I did change the screws to stainless to avoid rust and then put a dab of black paint on the screw head so as to blend with the black mud guard. On my 2013 there was one hole required in the rear quarter. The other holes matched existing factory mounts.
As the rear quarter is plastic it took about 10 seconds to drill a small hole back there. The whole job took about 30 minutes and as I previously stated, they're still on the car and look good. Mud guards do save the paint around the wheel well. Some members who installed the mud guards had them painted body color. I like the black as a contrast. GOOD LUCK if you decide to go ahead with the project.
The rear quarter where the rear guards are mounted is plastic. No rust issues. I can only speak of the procedure for the gen 6 ES cars, but think probably it's the same for 2019.
https://www.ebay.com/itm/4pcs-Molded-Mud-Flaps-For-Lexus-ES-F-Sport-2019-Splash-Guards-Mudguards/253981625916?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
They didn't get here yet so I'll let you know if they're good to go...
Edit: The mud guards just arrived and the holes match up perfectly with the factory splash guard inside the wheel well. Too cold to be messing with these right now, I'll wait for a warmer day to attack this and post some new photos...
No, not "my car club".
https://www.ebay.com/itm/4pcs-Molded...72.m2749.l2649
No. The holes in the mud guards will have to be matched with the clips (they are not screws on my car) inside the wheel well. IOW no drilling the car, only the mud guards...
I also found these too. They look the same. https://www.ebay.com/itm/A-Premium-4...cAAOSw0VBcd4bt
