Cost to own GSF
Cost to own GSF
So I am curious to know from most of you guys here what the cost to own a gsf is either new or used. I’ve heard some feedback from some owners whether it was the cost of tires every so often, or break pads and rotors. So wanted to see overall the cost to own. Thank you guys in advance.
I'll come at your question from a different angle...
The GSF is (much) less expensive to own and operate than most anything surrounding its classification/specification; i.e. high performance 4 door sedan with an MSRP > $+70K. Additionally and based on brand reliability/cost to own, it's the only car in it's segment that I would buy used AND intend to own outside of warranty. It's a bit of unicorn from that perspective.
At this stage in life, I no longer value "nth" degree of max performance at the expense of being tethered to dealer proprietary expertise, down time, and/or what feels like exorbitant prices (OEM or alternatives) for normal wear and tear items; i.e. pads, rotors, scheduled maintenance items, etc.. Cars considered when purchasing the GSF included preowned and varying years of E63, S6, XJR, XFR-S, CTS-V, & M5 all of which can be fantastic used values.
The CTS-V was running a close second and has fairly decent care & feeding costs but I've been down that road with prior generation ownership.
Finally, don't forget to get an insurance quote on your consideration set of vehicles - that's always interesting to understand.
Good luck,
Eric
Good luck,
Eric
To be quite honest the cost of ownership is relatively low considering the price tag on the car and the cars its compared to. The germans have ridiculous price tags attached to their services such as brakes and oil changes not to mention they lack in the longevity department. Just for reference here are the OEM list prices of brake components
Front rotors - $249.06
Front pads - $412.01
Rear rotors - $264.90
Rear pads - $622.64
A full oil change kit is well under $100 if you are going to do it yourself.
We all know The "cost of ownership" is also dependent on you, how hard you drive determines how often you change brakes, tires, etc; then comes into play what you use to replace them whether it be OEM or something aftermarket. These cars are fairly good with the cost of things and they will outlast all the competitors.
The most expensive things about these cars are the body parts ie grille, spoiler, headlights, rockers and lets not forget the cost of insurance for some; I was 27 when I purchased my GSF, with a clean driving record and no points I was quoted $483 a month if I was listed as the primary on it, but with my father listed as the primary its $187 a month, mind you this is in the five boroughs of NY.
Rear pads - $622.64
Tech Info Resource
I just bought Centric/Stoptech rotors and pads for all four corners from Rock Auto for under $600 including shipping. The only thing that would add significantly to that cost would be the wear sensors, but I plan to change everything out before the sensors get used.
From what I can tell - the front rotors are very close to minimum thickness after replacing the pads one time. The rear rotors and pads are approaching minimum thickness at the same time. The car just went over 40k miles, so it's pretty hard to complain about performance brakes wearing out at this point. I am a little surprised at the rears though. The IS F barely wears rear brakes at all, even on the track. I put 120k miles on my rear rotors and they were still above minimum thickness when I changed them out.
Tech Info Resource
I put Pilot Sport A/S3s on the GS F because they work in snow where the PSS are terrible in anything under 40F. Nothing but front end chatter and traction control lights. I have no practical reason to run summer tires on this car ever. It will never be at the track except to observe the IS F circulating.
i just replaced my first set of tires close to ~34,000 miles... i do mostly highway driving perhaps 75%, i do tend to drive it hard. the fronts still had some life left on them ( I kept one as a back up), im not to sure how the rears were as the 2 days prior i made sure they need to be changed.. I went a head and changed them out as mine is a lease, and didn't want to put on new tires just a few months before the lease ends. (sep 2019).
besides that and routine maintenance (oil changes) i haven't had any other expenses. im due for a service so well see if they tell me i need new brake pads. oh i switched out my wipers.
Just got my car back form the 35k service..
I got the following, my lease ends in September (I can drive up to 48,750 miles)
Service guy suggested I replace front pads and rotors...thoughts?
Either you can do it now, or they can charge you when you turn the lease in. I'd go ahead and do it now so that at lest you can wear them out some.
tnx
Ask @Lobuxracer, pretty sure he mentioned in another thread that the lights came on his dash for his GSF and he still was able to get something like 5000 more miles out of his brake pads. The lights come on very prematurely and thats by design.
This was also my initial thought, but was also thinking that there could be a chance of trading car in close to lease end date (another dealer, as of now possibly Jaguar). Not sure if they would be something they check at that time.
If I was going to trade, wouldn't touch it. They will low ball you on trade anyway. No sense in spending money to never recoup. They will always give you the..."we have to spend $x,000 getting this vehicle ready to sell." no matter if you drove it brand new off the Lexus lot to theirs.
madmantwo (10-11-20)
