Lexus Es300 (2000) Starts and stalls after replacing the battery
Hi!
Lexus Es300 (2000) Starts and stalls after replacing the battery. Most likely it is an immobilizer/ Help please who faced similar. Thank you!
Ridehigh69 (12-18-18)
Try locking then unlocking the doors using the remote do this several times. Do the same with the key in the drivers door.
Does the security light go out when you insert the key?
I disconnect my battery all the time something else is going on with your car.
Do all owners gave a car after the battery replacement the first time?
Replacing the battery resets the immobilizer stopped to recognize native the key. What actions can be used to restore the settings or re-register it?
1.) You would either have to remove the ECM and have it sent to be cleared.
2.) Or you can do it yourself to unsolder, recode and solder back a chip into the ECM.
The first route tends to be the easiest with less risk. Will cost about $80+.
You could call a locksmith and ask if they can reset the immobilizer with their equipment.
The following 2 users liked this post by ilkinandr:
harrisbaig (12-19-18),
philanges4 (01-30-22)
