Trunk Air Suspension display
Old 11-18-18, 05:39 PM
daniel1235
daniel1235's Avatar
Default Trunk Air Suspension display
Hi,
Been bored lately so decided to start a little project.
The factory spare tire wheel has my suspension set up. Its covered by the factory black mat. figure i may as well show it as the set up while not amazing is pretty nice IMO. Maybe when i have more money i can chrome all the lines and the tank but im not rich. I collected a million cans from garbage bins to buy this. JK.
Anyhow, purchased some plexiglass, traced, cut, fit, cut again, fit , and sand. Then covered the sound deadening with black carpet since it looked like aluminum foil.
Im not done yet as i want to cover the side and top portion of the plexiglass with vinyl to look something like the below. Originally was trying to add felt with glue on top of the plexiglass but its way too difficult to and it was looking ghetto. But you get the idea.Have to order carbon look vinyl so might be a little while.
Old 11-19-18, 08:44 AM
sha4000
sha4000's Avatar
It looks nice, Did you set this up with the OEM bags?
Old 11-19-18, 10:55 PM
daniel1235
daniel1235's Avatar
No. Im running Air Runner for equipment with Air Lift Performance for air management.
Old 11-20-18, 04:08 PM
MobbinVIP
MobbinVIP's Avatar
That looks pretty good! I wouldn't mind having that as my setup
Have you tried polishing the hard lines?
If not, try first on a scrap line, get some metal polish (metal wheel polish will work) use a microfiber or if you don't mind spending an extra $35 on the mothers power cone or power ball & attach to drill. Use a little polish at a time, the polish should turn black, whip it off. Should polish out to a chrome like finish.
Definitely, in for more!
metaleckz
12-05-19 07:00 PM
Ravill
LS - 5th Gen (2018-present)
05-02-19 09:01 AM
k311in
03-08-18 05:28 PM
Rawkus1513
CT 200h Model (2011-2017)
30
07-23-15 10:31 PM
Trefive
Suspension and Brakes
62
10-27-10 09:55 PM
Quick Reply: Trunk Air Suspension display
