Tire replacement or just wheel alignment is fine
Hi,
2013, Rx350 FSport, 55K miles
Currently has the following tires installed:
It is fine when we drive on a straight road, but sometimes during rainy day or snowy day , while reversing the car or making a big turn, the edges make some of skidding noise.
When I read online it says mostly because of Alignment issue because all 4 tires outer edge ring is worn out.
Question:
1) Do you think I should replace all 4 tires with brand new ones and then get wheel alignment done.
2) Will just wheel alignment be enough in my situation.
Thanks in advance.
Michelin Latitude Sport 3 Green X235/55R19
The tires have 4 rings. The outer edge ring has around 20% thread left. All four tires the outer edge has only 20% thread left. The inner 3 rings have around 80% thread left. All four tires are the same pattern and thread life.It is fine when we drive on a straight road, but sometimes during rainy day or snowy day , while reversing the car or making a big turn, the edges make some of skidding noise.
Question:
Thanks in advance.
This is the order I would choose;
Have the suspension checked. A good alignment shop will always check suspension.
Then get the alignment done.
Salim
Salim
Too dangerous!!! Replace the tires now!!!
I would get 4 new similar good quality tires (all season if you have below 40 degrees F with light snow possible OR summer high performance tires). Try to get the "low resistance" / "GreenX" in Michelin brands or whatever designation in other major brands......for better mpg.
If you are in SoCal and don't go to the ski slopes, then high perfermance summer tires is good. But if there is any chance temperature drops to below 40 degrees F, then get all seasons tires (the rubber turns very hard starting at around 40 degrees F and you will not have any traction even if the roads are dry.) . If there are going to be lots of snow, get dedicated snow tires.
After getting new tires, get 4 wheel alignment ASAP. And watch for uneven wear.
We did LIFETIME 4 wheel alignment fir our RX450h at Firestone with a nation wide warranty for life....it was on sale as I recall for around $169. They usually have sales during major holidays...... The going rate for a one time 4 wheel alignment is around $99 to $129 elsewhere. (Lexus dealers in my area charges around $169 as I recall). The one time alignment usually gives you about 60 days of free adjustments if needed.
BTW, these tires on the RX will not last but like 25K miles to 35K miles. The all seasons type will lasts 35+k miles and the summer tires often less than 25k miles.
We replaced with Michilline LTX tires for our RX450h (it had the FSport appearance package with 19 inch wheels)
Hi,
Question:
Thanks in advance.
Question:
Thanks in advance.
We live in Chicago IL.
Which Model in Michellin tires do you rall recommend ?
I was actually planning to get replaced in Costco,but as per the previous post if Firestone has $169 lifetime 4 wheels alignment I would get that.
Would Nokian all-weather be an overkill in Chicago? https://www.nokiantyres.com/all-weat...therproof-suv/
These have been getting good reviews in the forum and elsewhere.
OP, you have to figure out first WHY your tires wear out at this pattern. Or, you WILL be tossing money at tires till you own the car.
Either your correctable alignment is out of spec, likely toe in or, worse, your camber is out of spec. As then there is no alignment option for that and you must install camber bolts and that's where $70 alignment job turns into $300 in good case.
Do NOT replace tires until you have alignment back to spec.
Also, tires should have never been allowed to get to such pitiful condition. It's lack of rotations.
Also, what is it with obsession with Micheline? Like as if it's the god of tires. I'll put Yokohama over Micheline hands down.
As has been previously pointed out, suspension component quality and condition plays a major role in tire longevity as does having a proper alignment set-up.
My current favorite bang-for-the-buck SUV/Crossover all-season tire is the General Altimax RT43. A decade ago, it was the Bridgestone Alenza (which I installed on my wife's previous 2004 RX330 AWD). I have had a set of General Altimax RT43 tires on my 2013 Subaru Outback 3.6R Limited AWD for nearly two years now. They are outstanding in the snow, have never hydroplaned in the rain, continue to deliver a quiet and comfortable ride, and come with a 60,000-mile treadwear warranty. Our recently-acquired 2015 RX350 FWD came with a new set of Kumho Eco Solus KL21 tires (size 235/55R19) that are probably going to be rather mediocre in both performance and longevity. Once they wear out, I will install a set of these Generals.
I agree with you. That's why my original question was either to fix the alignment first or get the new tires as well.
Lets say I get the alignment first And later they recommend to put new tires. After new tires they recommend to align again.
Instead of doing alignment twice.
If just an alignment will fix my tires, I'm good with that. But since the outer edges are already worn out
I thought of getting new tires + alignment done. And going forward keep looking at the tires and making
sure they are rotated or aligned as and when required.
The only reason I was going with Costco is because we recently got membership there.
And thought Costco has life time rotation,flat tire repair free for lifetime as long as you own the car,tires and Costco membership.
I'm sure there is a catch with membership.
But if there are other 3rd party tire shops who give the same deal and lifetime flat tire fix and rotation for same price
I can go with any shop, doesn't need to be Costco.
Let me know what you guys think.
Thanks again.
Thanks again.
We've had Yokohomas in the past. They are ok. We still liked Michelines better.
Most stores will beat Costco's pricing.
Here is Firestone info. I put in a general Chicago's zip code and a 2013 RX350 FSport.... $79 alignment for one time. $199 for LIFETIME. But there is a coupon for $40 OFF Black Friday!!!
So it may be just $39 one time or $159 LIFETIME!!
https://www.firestonecompleteautocar...savings-event/
https://www.firestonecompleteautocar...nment-results/
Thanks very much LexusRus for the info.
Is the alignment offer below what you mentioned is for 1 tire or all 4 tires ?
We did Firestone LIFETIME 4 wheel alignment (where needed and they are able to adjust bc not all suspensions setups are adjustable) for our RX450h and RCF. We tried to do on our LX570, but Firestone was not able to due to the hydraulic up and down Automatic Height Control, AHC, system. As soon as the tech started to adjust, our LX570 started to go up and down. I guess they did not have the right software or did not know how it use? IDK.
But for our RX450h and RCF...... absolutely no issues.
I was told to do the alignment with new tires on. BTW, we got new tires at America's Tires for the RX450h (Michelin Defender LTX) best deal for us including install and reprogramming the TMPS. My RCF was at work at a different location so I ordered online at it's sister's store (Michelin Pilot Sport A/S 3 Plus) , DiscountTires.com. Best price also....better than Costco, better than TireRack.com.
The Firestone stores just could not match the prices on Michelin tires from America's Tire/Discount Tires. The spread was a couple of hundred dollars difference on a set of four!! Firestone did have fair prices on it's Firestone and it's sister brand Bridgestone tires.
Long time ago we used to get tires from Costco. We are still Costco members. Nothing against Costco. It's just they are too busy. Also America's Tire/Discount Tires offer free nail patch repair and air ups, free tire rotations EVEN IF YOU DID NOT BUY FROM THEM!! They always gave me excellent service. This is their NATIONWIDE POLICY.
America's Tire/Discount Tires may have the optional "Road Force Balancing" which I got for my RCF. For the RX350, you may not need this since it's not a "perfermance car". But for smoother ride, you may want to consider. Also there is the up sale for the "LIFETIME balance" which we did not get. Then there is the up sale to completely replace your TMPS which we did not get bc I figure our cars are not that "old yet". Even if the TMPS failed, we'll just replace them at that time which is not that hard for them to do. Just make it clear to them you don't want anything OPTIONAL
https://www.discounttire.com/store-locator
https://www.discounttire.com/promotions
Hi Everyone,
I'm the OP for this thread..................................................
I just now took my Lexus Rx350 F sport to Sears auto center for a Wheel Alignment check.
And the results show that it FAILED. So they are recommending to get new tires and then do wheel alignment.
Here are my wheel alignment results
