Considering port&polish or swap?
I'm considering having my heads ported and polished, but I understand that lexus did this better factory on the RCF and GSF, would the heads from one of those be swappable with our engine? Or would I be better off having the existing heads P&P?
Tech Info Resource
The heads are not swappable. The engines are depending on how much work you want to put into it.
Porting will add some, but you have to decide if the increment it will likely achieve is worth the effort. Polishing is what poor tuners do to impress the customer and ruin the performance.
Tech Info Resource
It might help you:
http://speed.academy/10-myths-of-cylinder-head-porting/
Tech Info Resource
The one thing you will NOT get is a large jump in power. It will be incremental. However, choosing to do this combined with forced induction will make your engine more powerful than any other boosted one. All the gains from the conventional stuff you do translates to more power when you forcibly push more air than if you hadn't done it. It's just not economical for most people if you have to pay someone to do it for you.
tacosmashr (11-27-18)
Yes I agree with lobux all you can do to these head is port match, 5 angle valve seat cut and general clean up, you cant fit bigger valve's without huge expense, IF you could fit large valves you are going to loose velocity speed at low rpm. I have ported a lot of head to, and unless you match it to the cam specs 'which you cant change' compression levels, and a dozen more things and don't have a wet flow bench forget it.
Tech Info Resource
Ports, valve sizes, and cams all have to be matched, as does rod ratio, or breathing is labored. They call it tuning because it is a symphony, and any single instrument drowning out the rest is a disaster. So, when you choose to change one thing, at least a half a dozen other things need to be changed.
I would say don't worry about it until you're looking for the finishing touch or in a very competitive series where 2 or 3 percent will make a significant difference.
tas02 (11-15-18)
I remember lobux was thinking of doing a port job on his car well we are still waiting LOL, I hope you have access to a flow bench and valve-seat cutters because that is where a lot of power can be made, more than porting on these heads cheers.
It is simpler and maybe even more economical in the long run to just supercharge your F. I have no knowledge of porting, but I would hate to be the ginny pig on such an expensive drive train.
I think the boosted Fs can hold their own against most cars they meet.
