Driver AND passenger side air vent cupholder, succes! :)
Old 10-17-18, 11:04 AM
MikeB139
MikeB139's Avatar
Default Driver AND passenger side air vent cupholder, succes! :)
I've read about a few people that played with the idea to have an extra cupholder below the vent on the passenger side, but didn't find any threads that actually performed this operation.
Yes, it's an operation
I ordered the cupholder from ebay from a British seller.
It came well wrapped and in a new like condition.
Step 1:
Remove the glovebox. There are enough tutorials online about that
Step 2: gently pull off the air vent face. It's only clipped in at the right side bottom and at the very bottom (in the middle).
3. Pull out the air vent. It's held in place by two plastic retainers on the left side. Just push the air vent to the right and you can see them (and unclip them with a screwdriver or plastic spudger)
4. Start cutting!
The bottom plastic bit has got to go. Just the part where you clip in the cupholder needs to stay.
I was constantly fitting and cutting (that why the glove box is in place).
Below the part where the air vent clips in (the rectangle bit) I had to remove even more, since the cupholder is shaped a bit differently.
5. unclip the large cable tube and push it to the left. There is enough room for it to sit between the cupholder mechanism and glovebox. It won't rattle because it's quite stiff.
It's clipped to the metal tube behind it. You can just gently pull it lose.
6. slide in the air vent WITH cupholder.
I pushed it back a little more to be flush with the dash.
It's like factory now
SJM (08-19-21)
Old 10-18-18, 12:42 AM
J$mooth23
J$mooth23's Avatar
Nice upgrade there boss. How much was the part?
Old 10-18-18, 01:47 AM
MikeB139
MikeB139's Avatar
47,50 euro / 55 dollar. Cheap enough to try it
Old 08-13-21, 11:49 AM
Gibbs
Gibbs's Avatar
A few years back, I found the other threads where this idea was batted around, but just now found this one where it's actually been done. Would you mind sharing your source for the part?
Old 08-14-21, 03:25 PM
DennisMik
DennisMik's Avatar
The OP stated he bought it on ebay. This thread is almost 3 years old, so the odds are pretty good the seller is gone. But search - there may be another one.
Old 08-22-21, 04:44 PM
Felix
Felix's Avatar
We just use the cupholders in the console, never used the driverside cupholder.....
MJN331
10-27-19 07:43 AM
kent2174
NX - 1st Gen (2015-2021)
09-18-18 10:32 AM
GKsSC430
01-03-15 04:02 PM
chiro
02-01-11 03:49 AM
Quick Reply: Driver AND passenger side air vent cupholder, succes! :)
