Horn Relay??
Old 10-16-18, 06:40 AM
iolmaster
iolmaster's Avatar
Default Horn Relay??
I am having an intermittent problem with the horn. Sometimes it works, sometimes it doesn't. It is not dependent on the steering wheel position so I doubt it has anything to do with the spiral cable. (still possible) It is obviously not the fuse so my question is, do we have a horn relay and if so where is it? I have searched both on this form and the internet in general and can't find anything specific. Any help is always appreciated.
Old 10-16-18, 06:52 AM
GmanSC
GmanSC's Avatar
Ít can only be one thìng: *the switch, IMO.
Old 10-16-18, 07:05 AM
iolmaster
iolmaster's Avatar
I just did some additional checking.* It is wheel position dependent.* When the wheel is straight the horn will not work.* Turned to the left it works.* So, my guess is the relay is not the issue.* It appears it is in the steering column.
Old 10-16-18, 07:40 AM
GmanSC
GmanSC's Avatar
In that case, it’s a spiral cable or it connection to the switch most likely the latter.
Old 10-16-18, 09:33 AM
DshngDaryl
DshngDaryl's Avatar
I think this is an indication of a Spiral Cable issue.
What year is your car? There are two (maybe even three) spiral cables for the SC, getting the right year is important. Believe it or not, a non oem clockspring cable for the latter years can be had for like $20
Old 10-16-18, 09:38 AM
iolmaster
iolmaster's Avatar
What year is your car? There are two spiral cables for the SC, getting the right year is important. Believe it or not, a non oem clockspring cable for the latter years can be had for like $20
Yeah, I think it is the spiral cable also. The mode buttons stop working at the same time the horn stops. so, I am 99% sure it is the cable. The volume up and down still work. I have a 2006 and the OEM number is
84306-51030. I can get one of those for about $180. I did see some on eBay for about $40. Wasn't sure how reliable they would be.
Old 10-16-18, 09:57 AM
editordz
editordz's Avatar
I had the exact same problem. Had the spiral cable replaced last week, now I can let the world know of my disdain for other drivers again
Old 10-16-18, 01:15 PM
DshngDaryl
DshngDaryl's Avatar
Yeah, I had that same quandary too. Didn't really want to pay $375 for one from the dealer, but I also didn't want the airbag (that would most likely save my life) to be dependent on a clockspring made in China.
I ended up with a used OEM one.
Old 10-19-18, 12:54 PM
JohnnyCake
JohnnyCake's Avatar
Yeah, I think it is the spiral cable also. The mode buttons stop working at the same time the horn stops. so, I am 99% sure it is the cable. The volume up and down still work. I have a 2006 and the OEM number is 84306-51030. I can get one of those for about $180. I did see some on eBay for about $40. Wasn't sure how reliable they would be.
I have had three spiral cables in 150,000 miles on my 2006.
Old 10-23-18, 11:03 AM
GmanSC
GmanSC's Avatar
I've owned more than 10 automobiles so far, not single one has horn problem. I thought this problem never occurred.
Boy, I'm so wrong.
Nettes777
06-23-22 04:00 PM
johnnylt
11-15-18 05:21 AM
aschulz261
RC F (2015-present)
02-22-17 05:27 PM
Aliceto
GS - 1st Gen (1993-1997)
03-27-16 09:56 PM
propcop
01-24-16 03:46 PM
Quick Reply: Horn Relay??
