Odometer Stopped
Old 10-15-18, 04:05 PM
Moarpower
Moarpower's Avatar
Default Odometer Stopped
So my odometer stopped about 100 kms ago. Anyone fixed this before? 1990 model
Old 10-15-18, 04:34 PM
Sin1UZFE
Sin1UZFE's Avatar
Mine does it, usually smack it and its back to normal
Old 10-15-18, 05:25 PM
Moarpower
Moarpower's Avatar
Hoping to find a more permanent solution. Can really smack the odometer
Old 10-15-18, 05:36 PM
Sin1UZFE
Sin1UZFE's Avatar
Permanent solution would be to remove entire unit open it and clean it out. Apparently some oil makes them stick.
That's if it's not dead and just stuck. Smack it and see if it starts working.
Old 10-16-18, 07:34 PM
CELSI0R
CELSI0R's Avatar
You can replace the unit with a new or working one, and adjust the mileage to match, or inspect and possibly attempt to repair yours. Sometimes, a gear fails in the unit.
Check out this thread, regarding the gear:
https://www.clublexus.com/forums/ls-...l#post10053692
Old 10-17-18, 01:30 AM
PhilipMidd
PhilipMidd's Avatar
Mine appears to have stopped as well. About 5K ago, I would extimate. I've had the car for 9 months, I typically do about 20K a year. I know the car was at about 180 when I purchased it, now its at 190, but I have recently noticed its no longer advancing.
I'll try tapping it. The Red 1Km digit still goes around, but the 10's and so on are not.The interesting thing is the x10 digit is stuck on 5, and not 9 as you would expect if its a gear failure. Will have a look at it on the weekend. Will take pictures.
BossLex
12
01-14-21 11:31 AM
yojimbosc
05-04-15 09:58 PM
tuterz
06-10-14 10:26 AM
Sgtnapsc43
04-05-11 12:38 PM
Quick Reply: Odometer Stopped
