Windshield Washers
Old 10-03-18, 02:09 PM
jud149
jud149's Avatar
Default Windshield Washers
The driver side washer spray on my '11 LS460 is way too low on my w/s to do any good. Is there an adjustment on these? I did try to clean the nozzle with no results. It does not seem to be a pressure problem. The nozzle itself appears to be in a fixed position on the under side of the hood.
Old 10-04-18, 06:12 AM
Chuckinnj
Chuckinnj's Avatar
Try blowing some compressed air through the nozzle hose....... Most of the time cleaning the nozzle tip with a pin will work too.
Old 10-05-18, 01:25 PM
bigsherv
bigsherv's Avatar
Yeah that is what a shop will do, try it yourself first. Sometime a staple will clear some sediment out of the way and it will spray normal from then on.
Old 10-08-18, 02:19 AM
jud149
jud149's Avatar
I ended up ordering a new nozzle. Compressed air didn't help. Actually the Lexus shop manual says to replace them if the spray is erratic. $20 shipped Amazon.
This is the first time I've used my hard cover manuals that I got when from the dealer when I purchased my 2 year old '11 LS460 back in 2013. There are 7 books included and they stand 15 inches high. Retail for these was about $1700 at the time that the dealer got for me for around $500. They're quite good from a procedure standpoint. Lots of pics.
Old 10-17-18, 02:58 PM
jud149
jud149's Avatar
Turns out the problem was the valve to which the 3 hoses attach, the supply and then 1 for each nozzle. This part with the hoses is attached to the underside of the hood under the insulation piece. This I removed for easier access. This apparently is a part that not uncommonly goes bad. Here it is:
Grouchy
03-14-19 10:52 PM
irishbrahm
10-13-15 11:01 AM
melnick
06-07-13 07:46 AM
trickshot4
04-16-13 06:06 AM
johnnyg66
02-28-13 09:38 AM
Quick Reply: Windshield Washers
