FIREHAWK INDY 500 Size
I currently have 275/30 on my stock rim which this size is on back order. So does anyone run 285/30 on the stock rim? Any issues with running this size.
What year ISF, wheel widths changed increased by ½" in 2012. I ran 285s on my stock 9" wheels, but that's wider than tire manufacturer's recommendations. 285/30 on the later 9½" wheels would be no problem. BTW, a search would have led you here:
https://www.clublexus.com/forums/is-...-position.html
Lou
Lou
ISFCOBRA (09-24-18)
Speak of the devil, I'm planning on running these tires as well. Was wondering what is the max size I can run them with my 2012 wheels dropped on Swift springs without rubbing on stock fenders. I was planning on running 245/35/19 in the front and 275/30/19 in the rears. Was wondering if anyone else up-sized their tires without fender modifications/rubbing?
Plenty of people running 285/30 on stock 12 plus rears.
Exact sizes I went to recently on my '12 F and I'm lowered on all 4 corners on swift springs and zero rubbing. Whenever I need new rears, I'll try 285/30. I also still believe there's room for a 15mm spacer to finish the flush look off.
V.
I've been running 245/35 and 275/30 in these tires on my 2012 for 1.5 years with no issues. I do have swift springs in the front only. When I get my next set I'm planning on going with 255/35 and 285/30 which shouldn't present any issues with fitment.
EDIT: I'm going to do 255/35/19 and 275/30/19, my friend says 285 is a bit wide for 9.5 wheels. Some complain of being too "boaty/flexing".
Just ordered 255/35/19 and 285/30/19 pole positions. Have 2012 wheels and lowered on Swift springs.
Will report back when they come in and get installed - hoping no need to roll fenders.
Just got them installed. No clearance issues front or rear. Ride quality is much smoother/quieter compared to the old Pilot Super Sports (stock sizes). Soon as they are broken in I'm sure it'll be light years ahead traction-wise as my old tires felt like driving on ice.
Also happy with visual difference going from 255 to 285! (left side:255, right side:285)
^^^^255/35/19 will work fine an an 8½" wide wheel. I'm running 255/35/19 and 295/30/19 on my RCF wheels. No issues up front. I believe Lance is also running 255/35/19 on his 2012 wheels.
BTW, your friend is wrong.
Some folks did complain when they were mounted on a 9" wheel, but not on a 9½" wheel.
Lou
Lou
F Monster (09-24-18)
Lou
Lou
Lou
Lou
I’ve got that from a lot of people. But for the money and the comparative performance, they really are hard to beat.
Took a gamble on them and couldn’t be happier. Lot of people have tried them on different makes and models and have said the same thing.
F Monster (09-25-18)
