changing head light to led
Old 09-21-18, 01:54 PM
a371990
a371990's Avatar
Default changing head light to led
Hello there,
my car is LS 430 2005 and i have one head light bulb burned out and i decided to change it to LED, so please advise me with the bulb type and the required wires or connectors name.
Regards,
Old 09-21-18, 02:21 PM
yardie876
yardie876's Avatar
It's not worth the hassle and light output decrease IMO. Just purchase a set of 5500k HIDs and you'll get factory performance with a nice color.
Old 09-21-18, 09:32 PM
a371990
a371990's Avatar
the stock one is expensive, do u know aftermaket one with good performance?
Old 09-22-18, 03:12 AM
rkw77080
rkw77080's Avatar
Please take a look at the post below...
https://www.clublexus.com/forums/ls-...placement.html
A pair of new headlamps go for less than $80 on Amazon.
Old 09-22-18, 06:21 AM
yardie876
yardie876's Avatar
An addition to the thread rkw posted above, check out theretrofitsource.com for bulbs. I've purchased their products for many projects and I'm pleased with their quality.
Old 09-22-18, 07:02 AM
a371990
a371990's Avatar
thanks for ur help but one more question what about the high beam i wanna change it to white instead of stock orange what do u suggest?
Old 09-22-18, 07:32 AM
rkw77080
rkw77080's Avatar
Please take a look at the link below on a discussion about high-beam light bulbs.
https://www.clublexus.com/forums/ls-...rl-lights.html
Old 09-23-18, 10:00 AM
a371990
a371990's Avatar
Sorry but it dosent mention the any thing about the high beam, could u tell me for which type of bulb i should look for and which type of connector or plug so i could do the research and buy it.
Old 09-23-18, 12:13 PM
rkw77080
rkw77080's Avatar
As discussed on that link, the high beam light bulb uses the 9005 socket type. The link mentioned that when low beam (D2S) is off, the LS430 sends reduced power to the high beam (9005) so they function as DRL (Daylight Running Light). When the low beam (D2S) is on, the "Clearance" bulbs (194) function as DRL.
Old 09-23-18, 01:12 PM
jayclapp
jayclapp's Avatar
I personally think it should be against the law to change headlamps to be brighter than the OEM that the car came with from the factory. I have seen too many headlamps that are actually blinding in bright daylight. What for? It's like the driver is screaming "look at me, I'm an idiot and could care less about anyone else"!
Old 09-23-18, 01:48 PM
Bsavage
Bsavage's Avatar
Im running 4 DDM TUNING HIDS 80$ headlights and fog lights are bright white and i deleted the day running lights
Old 09-24-18, 01:32 PM
caverman
caverman's Avatar
+1
Check with them. I've used their stuff in the past with good results.
misterlv
03-21-14 10:19 AM
glau
04-25-13 08:52 PM
TitanFan
09-04-12 06:11 AM
energie8
Lighting
20
07-06-12 05:49 PM
Quick Reply: changing head light to led
