245/40/19 rub with front wheels? Square setup
Old 09-18-18, 01:01 AM
monoglot
monoglot's Avatar
Default 245/40/19 rub with front wheels? Square setup
Hi all,
Do you know if 245/40/19 would rub in the front wheels all on stock suspension with full load? Looking to do this with a square tire setup.
If not, would 235/40 work? Or would I have to go to 235/35 for it not to rub?
wheels are 19 x 8.5 +32
Thanks in advance!
Old 09-18-18, 01:16 AM
smithy63
smithy63's Avatar
I would think this would be ok. I have 19x8.5 +40 with 245/40/19 tyres and have heaps of clearance
Old 09-18-18, 08:42 AM
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
245/40 tires are nearly 1.5" over factory diameter. You should probably be on 235/35.
Old 09-18-18, 10:47 AM
jkonquer
jkonquer's Avatar
245/40/18 is ok on a factory wheels for the front. I think it should be ok since the offset vs width of the wheel is similar to the factory ones, but may want to look into 35 instead of 40.
Old 09-18-18, 06:12 PM
smithy63
smithy63's Avatar
The 245/40/19 tyre is almost exactly the same diameter as 225/55/17 tyres that were standard on my car
Old 09-18-18, 06:54 PM
smithy63
smithy63's Avatar
Stock 225/55/17 tyres on my car measure 679.3mm diameter and 245/40/19 tyres are 678.6mm so actually just smaller in diameter.
Old 09-18-18, 06:55 PM
smithy63
smithy63's Avatar
https://www.willtheyfit.com/index.ph...8-5&offset2=40
Old 09-18-18, 08:54 PM
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
F Sport has 225/40/18 .. which is 1" larger. If that's not your model .. my mistake.
Old 09-18-18, 09:46 PM
smithy63
smithy63's Avatar
No problem mate-i'm in australia so maybe we had different tyre sizes here. I know we never had 16" rims like you had there but our 17" rims had 225/55/17 tyres and 18" rims had 245/45/18 tyres standard. This is for an LS430-maybe I mistook what car it was intended for?
Old 09-19-18, 01:25 PM
arentz07
drives cars
arentz07's Avatar
Received 3,510 Likes on 1,806 Posts
F Sport has 225/55/18 .. which is 1" larger. If that's not your model .. my mistake.
What?
I have 225/40R18 in the front, 255/35R18 in the rear on my F Sport. And all F Sports have the same wheel and tire sizes.
Old 09-21-18, 04:50 AM
ShrinkDoc
ShrinkDoc's Avatar
I run 225/50/18's on the front with zero issues (255/45/18 rear). Based on the tire size calculators on the web, you should be fine.
Old 09-21-18, 03:17 PM
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
Originally Posted by arentz07
What?
Your right. Not sure where that 55 came from. 225/40/18 is right.
Old 09-21-18, 03:18 PM
arentz07
drives cars
arentz07's Avatar
Yeah... so 245/40R19 would be about 1.6 inches more than the stock tire diameter. That seems high IMHO.
Old 09-22-18, 12:27 AM
ShrinkDoc
ShrinkDoc's Avatar
The diameter on my wheels is approximately 3" larger than OEM. It does fill the wheel well while maintaining width, and in the end, the car is 1.5" taller than stock, the ride is significantly smoother, there is zero rubbing, and the speedo offset is 3mph at 60 mph..
It makes sense for the NE given the potholes and ice rocks in the winter.
Rider
IS F (2008-2014)
01-19-12 07:48 PM
neomedic
01-18-12 07:55 AM
autoboy
Wheels and Tires Classifieds
08-20-10 10:56 AM
IS3_FTW
Wheels, Tires & Brakes Forum
04-01-09 08:24 PM
NoS
06-06-05 01:39 AM
Quick Reply: 245/40/19 rub with front wheels? Square setup
