Accessory Power
Accessory Power
When I turn off the engine in my Cadillac STS-V, the accessories (radio, windows, roof, etc.) will still work for about 15 minutes. With my GS350, it doesn't allow that. Is that a setting issue? I would like for it to continue to work for a short time (like most other vehicles) when I shut the engine off. Any help on correcting this?
Thanks.
Thanks.
The only way to retain accessory power is to turn off the car while the gear selector is in a position other than Park (I use neutral). Then you can move the selector to Park and your power will stay on for about 10-15 minutes.
The following 5 users liked this post by JDR76:
02REX (10-15-18),
bob256k (10-15-18),
ChronoR (10-15-18),
jonathancl (10-17-18),
mylehigh1 (09-17-18)
BTW, I just transferred from the submarine base in Bangor, WA to California. What part of Washington are you in?
THIS SHOULD BE STICKY-ED
thanks I never knew this!
It's in the Owners Manual.
When stopping the engine with the shift lever in a position other than P
If the engine is stopped with the shift lever in a position other than P, the engine switch will not be turned off but instead be turned to ACCESSORY mode.
Sticky the owners manual! LOL
WTH?!? you know how many push button cars ive had and never thought of doing it this way to keep accessory on?!? (MIND BLOWN)...lol. I always have to turn it off and cycle back to accessory! you should get Nobel Car Peace Prize for that info cuz you just saved me so much hassle! thanks bruh!
This really annoys me, it's a simple software change for Lexus. My Commodore ran all accessories until the driver's door opens, and then some for a period of time after. wish the Lexus did this too.
I shouldn't have to switch on accessories to operate the windows, but the only way around it is to rewire the power with a delay off relay!
Originally Posted by azipod
How do you get the Auto E-brake to engage if you turn the car off in Neutral?
No, it will not do it automatically until you cycle through the power again. So you need to put it in N, push the on/off button, put it in P, then reach down and push the parking brake button
When you put the shift selector in Park (after turning off the ignition with the shift selector in Neutral) the car is not going anywhere.
If I get out of the car, realise that my sunroof is open(why doesn't that close automatically?) I can't just get in and close it or a window, I have to cycle through the ignition stages first. Same goes for before I turn it on.
