Girlfriend used wrong gas
I let my girl get gas last night since I was swamped with work and she freaking messed up. Instead of using premium gas she used mid grade, I don’t know if this will cause an issue, it was only 20 bucks but still, I don’t want any issues. Does anyone have an idea ? It’s a 2013 GS 350 F Sport
ECL (09-12-18)
It will be fine. The knock sensors will adjust the timing if it senses knocking.
only time I can feel the difference is when flooring it to merge onto the freeway (black smoke with 87, no smoke with 93)
Also.. going on a low rev uphill.. car "shakes" with 87.. little smoother with 93..
take off from lights, a bit smoother with 93..
I pump 87 because the difference from premium is about 60 cents a gallon, so $10-$12 per fill-up.. which is a big difference to me.
ph0bolus (09-11-18)
Ahhh, ok sounds good to me. Started feeling different after a couple miles but it’s definitely better now. Will definitely not floor it for now and just re fill the tank with premium after it’s getting close to empty.
But anyhow, good excuse to make a stink. Make up is always great.
-Mike
ehhh.. maybe 1mpg.. i mean.. i do a lot of local driving so you know it's bad no matter what gas or liquid you put in the tank.
You can also do like a blend offset to hit 91 octane, which is the garbage premium they sell out in CA, which is what these cars were built around as a lowest common gas.
EG, throw in 10 gals of premium and another 5 gals of the cheap stuff and you'll be somewhere around 91 octane if your car is going to take about 15 gals of fuel (which is a typical, mostly empty GS tank).
Anything is better than having your car driving around running like garbage. These cars weren't designed to run with only crap gas in them.
-Mike
The following 2 users liked this post by MedicalDoc:
joedaddy1 (09-12-18),
Knucklebus (09-11-18)
Just be glad she didn't put diesel fuel in it. A tank of 87 won't do any harm whatsoever. Whenever there is a pipeline break or hurricane that causes a shortage of premium gasoline for a week or two everyone must use 87 octane. Even the high compression, wildly tuned Ferraris, Lambos and McLarens around here did okay with regular octane during the gasoline shortage as long as you don't put it under a full load.
Just like what everybody has said. You'll be fine. The ECU will adjust for the lower octane. What you can do is be easier on the throttle and when there's room in the tank for new gas, fill it up with the premium. If it makes you feel better, you can also toss in a bottle of octane booster right now. Relax, drive, and have fun with the car. no worries.
