RCF w/Invidia Exhaust 1/8th Mile & Dyno
Got the RCF dyno’d yesterday made some solid power. Took it to the track and ran 8.3 on 2nd run. Had a ton of fun will be going back soon.
Best Time was 8.3 take a look at that reaction time
Coming soon, was going to install today but I had a small issue with the passenger side PPE is fixing. Until next week...Cheers
The following 3 users liked this post by 1BAD4DR:
Cool video. Good kill on the Scatpack. So what were your Invidia dyno peak numbers? Do you have the PPE header yet or has to be installed?
1BAD4DR (08-17-18)
Awesome videos! Thanks for sharing!
Nice win. And you did pretty good with the demon 😅
What was your net gains from the Nvidia? Thanks.
1BAD4DR (08-17-18)
345whp and 324wtq on a superflow dyno. Unfortunately never got a stock run and per the dyno operator he converted the dyno/math to a dynojet # and it was 381whp (but whatever about that).
Yea somehow paired randomly with the demon but it was fun.
Looking to install headers and intake soon so ill have net gains over what I posted stock with exhaust. Never ran it stock on the dyno unfortunately.
Your 1/8th mile is very good as you got it under 2.0. Though, dyno numbers look a bit on the lower side (even 381 whp w/ exhaust is a bit low as it should be in the 400 whp range). Do you put Octane 91 or higher? I put Octane 94 and it is a very very noticeable difference in power and response.
Run 1 @8.4 was traction off/ sport+/expert mode/track TVD/auto
Run 2 @8.3 was traction held for 4 seconds fully off/sport+/ track TVD/ manual ( I did have to wear a helmet on this run and I think I might have forgot to shift/hit rev limiter lol it all happened so quick but I think I can hit a 8.2.
My advice, stay away from the Ethanol blend cr*p to boost up the Octane. I only put the Octane 94 that has no ethanol in it and is properly a high Octane fuel. I have had Octane 94 on nearly all of my fills except the first 2 fills when I bought the car. It does take a few drives for the computer to adjust, but then it works very well with the very high compression.
Since you are mixing 3 parts of Octane 100 for every 7 parts of 91, I think it would only more closer to Octane 92 and 93. If you mix it in equal 50/50 parts, you get around Octane 95.
Since your 1/8th mile is very good, it would be interesting to see what you get in the 1/4 mile. You figured out the difficult part. The top rpm is where RCF really comes alive so most likely your 1/4 mile would be quite good.
Yea I’m not using ethanol blend or additives not sure if I confused you. But I do have access to 100 locally so do you recommend 50% of the tank 100 oct and the other 50% of the tank to be 91octane? The problem is 100 octane is $9.99 a gallon.
I put Octane 94 in my RCF for $1.50/Liter. About $80 for the whole tank, but I don't daily drive my RCF so it lasts a long time.
1BAD4DR (08-17-18)
