rim damage from wheel cleaner
hello guys,
I messed up my Fsport gunmetal rims with Meguiers hot wheels. I have used this stuff forever but this time i may have left it too long. When I sprayed down the wheels, there are black marks and that wont come off.
Can I use something like compound to remove this? I dont want to damage my wheels any more then they are.
thank you
thank you
Received 1,732 Likes
hello guys,
thank you
thank you
The cleaner you had used corroded the gun-metal paint, thus the darker undercoat is showing now.
Have the same issue on my F sport rims caused by the previous owner. Only way to fix them is the get them refinished.
I would recommend using a acid-free based wheel cleaner next time.
I did plasti-dip expecting to not like it and remove it the next weekend. It actually looks fine. I've been asked 4+ times if I powdercoated. 6 coats of plastidip and 2 coats of clear on top.
However....it is not durable and starting to scratch. I will be taking it off soon to resurface wheels or powdercoat black again.
