Ac compressor
Old 06-20-18, 07:41 PM
Lonely77
Lonely77's Avatar
Default Ac compressor
My ac compressor kicks on about 5-10 seconds and shuts down I replaced the relay and it keeps kicking off.
Old 06-20-18, 09:36 PM
EddieK05
EddieK05's Avatar
I'd check your refrigerant level.
Old 06-21-18, 04:32 AM
Lonely77
Lonely77's Avatar
I had the system recharged last week. Maybe the compressor is just bad ?
Old 06-21-18, 09:49 AM
wavesonic
wavesonic's Avatar
You might want to check the system pressure, if the system is overcharged, then the AC compressor will shut off prematurely to prevent damage.
This happened with our 2004 Sienna, where I had to get the shop to remove some of the refrigerants in order to have the compressor running properly.
Old 06-21-18, 03:07 PM
EddieK05
EddieK05's Avatar
Could be a few issues. Refrigerant is low, is overcharged, could be a relay switch. How often do you have to recharge your a/c? If often, you have a leak somewhere. Don't use the a/c until you get it fixed, you'll burn up the compressor if it's still good.
Old 06-21-18, 07:30 PM
Lonely77
Lonely77's Avatar
Just replaced the relay , literally just replaced the compressor and recharged it .
Old 06-21-18, 08:10 PM
EddieK05
EddieK05's Avatar
Did an a/c shop recharge it? I'm not doubting your aptitude if you did it, but refrigerant level is critical. Too low or too high and it won't work properly.
pdavid2204
LX - 3rd Gen (2008-2021)
12-06-17 09:29 AM
texsexlex
06-07-17 03:09 AM
2JZPOWER
19
09-14-07 03:32 PM
tuninghaus
04-11-07 07:35 PM
kathleenkmh
Performance & Maintenance
33
08-02-03 11:36 PM
Quick Reply: Ac compressor
