Customizing Vehicle Settings by Dealer
I'm about ready to bring mine in for the first service and will request the following vehicle settings be customized by the dealer:
1. POWER WINDOW – Wireless remote control linked operation (open only) - CHANGE TO ON. (Ability to open windows with fob)
2. REVERSE WARNING BUZZER – Signal (buzzer) when shift position is in R – CHANGE TO SINGLE (Eliminate continuous BEEPS while in reverse.)
Any members have other settings changed that can only be done by the dealer?
I have had the soft blinker setting changed to 5 instead of 3. Also I have had the reverse warning beep changed to single... Just be aware of when you do this because you can easily forget its in reverse esp if you arent paying attention to your backup camera.
A few months ago someone posted a link to five pages worth of options you can have set by the dealer. I filled mine all out before my car arrived from Japan and gave them to the dealer so he could set them all to my preferences before I took delivery.
Besides power windows open using wireless remote, I had dealer set power windows to open and close using the mechanical key. It's a bit tricky to to use the key but it works just fine.
oilman,
You are absolutely correct. When I did a search for this I didn't notice there were multiple page results.
I think they are all listed in the manual, but here is the official PDF of the functions that can be changed:
https://www.lexus.com/documents/broc...navigation.pdf
walkedu,
Famous last words, but I've never had a vehicle that had multiple beeps when it's in reverse, so I don't think that's going to be an issue.
I'm still going to go with the two I listed in the OP.
Thanks to all for the replies.
walkedu,
hi guys, my LC should be delivered this tuesday and have also printed out the dealership only programmable options. like OP i have the power window and reverse buzzer on my checklist, but my primary concern is the side mirror fold/extend options as my current garage narrower than i'd prefer and from what i've seen the widest part of the car seems to be at the side mirrors. it appears factory default for the mirrors to fold based on driver's preference when shifting in reverse, in addition to automatically folding when the door is locked, can anyone confirm? i imagine a folding option in any other situation would be deemed unsafe, but it would be nice to have that option as well. thanks
gvd,
I think you may be mixing up the mirror FOLD IN with the TILT DOWN in reverse function.
I can't be 100% sure, but I think the TILT DOWN IN REVERSE is standard.
The FOLD IN when locking is standard and the dealer can program them to fold when you shut the engine off.
My garage is also narrow, and my "gauge" for if I'm lined up well to enter IS that exterior right-hand mirror. In my application, I wouldn't want it to fold before entering the garage because I know if the mirror clears, I don't have to worry about the WIDE rear fenders scraping against the doorjamb. I've been using that method for umpteen years with all my vehicles.
gvd (06-21-18)
1) Close Windows with Mechanical Key - Turning the key right and holding the position for 2 seconds will close the windows = On
2) Open Windows with Mechanical Key - Turning the key left and holding the position for 2 seconds will open the windows = On
3) Open Windows with Electronic Key - When pressing the unlock button on the electronic key for 3 seconds: All the windows will open = On
4) Driver Seat Belt Reminder - The driver seat belt reminder will not beep = Off
5) Passenger Seat Belt Reminder - The passenger seat belt reminder will not beep = Off
6) Reverse Beep Alert - The alert will beep once = Off
My side mirrors formerly tilted downwards when I was backing up. Then, when the dealer turned off the multiple-beep reverse sounds, when I got the car back home I realized the side mirrors no longer tilted downwards when I was backing up. So perhaps he took creative license with all sorts of stuff. Goin' back in.
Thorne,
Geez, I wonder if that changes when they remove the multiple reverse beeps.
Anybody who's had this done, did you "lose" the tilt-down in reverse feature?
