1999 Lexus Rx300 cigarette lighter relay location
Old 05-24-18, 07:24 PM
cpchambe
cpchambe's Avatar
Default 1999 Lexus Rx300 cigarette lighter relay location
hello guys, Fuser is fine, but cigarette lighter still has no power, thanks.
Old 05-25-18, 07:05 AM
mrblister
mrblister's Avatar
Post your question in the correct forum You posted this in the sc430 forum
Old 06-20-18, 03:12 AM
Australian
Australian's Avatar
Does the lighter work if you plug it in the backseat centre console? I am having same issue and thought it might be the lighter itself as did run a phone charger from the back but a lighter didn't work in either front or rear. I put it down to wrong not making contact or broken wire in lighter. If there is a relay not working then I am wondering what else isn't working as doubt one relay for a lighter alone.
Old 06-20-18, 04:08 AM
mrblister
mrblister's Avatar
Default Wrong forum
you might get better responses if you post this question in the correct forum this is the second time I am telling you
Old 06-20-18, 06:13 AM
maxSteel
maxSteel's Avatar
From the info I have I think this is the case
The RX300 has 3 power outlets.
The front one is called the CIG Lighter and is on fuse 5.
I don't see a relay for the CIG lighter.
The center console and trunk ones are call PWR outlets and are on fuse 7.
The ACC relay switches the PWR outlets. It is located bottom-right in the instrument panel junction block by the fuses.
kevin3344
10-24-18 03:58 PM
Brabusx2
04-23-17 11:53 PM
NguyenD408
01-17-09 05:58 PM
Carboxy
07-11-04 10:48 AM
Quick Reply: 1999 Lexus Rx300 cigarette lighter relay location
