water pump for AWD v RWD?
hi again guys. so i found a quality water pump , but the listing says for Manual trans, then another for RWD AUTO , but not one for AUTO AWD.
ive contacted support and was told if thats what it says, thats what it says.
is the waterpump on an AWD a different fitment than the RWD? . i guess i can understand it may be different with a manual trans, but AWD v RWD? could someone who knows tell me please!
bryceis250 (05-21-18)
so your 100 % positive? is this also the case with automatic vs. manual transmission in this car? just curious.
ehy aspect, what say you? aftermarket from Rock auto for 90 with gasket , or the lexus , which the cheapest i can kind is 160.00; this one of those places skipping the lexus parts is ok?
do you have an opinion on serpentine belts?
aspect i was wrong its not the waterpump its the tensioner pulley set im looking at thats making this distinction, the pulley belt and tensioner. this will also be universal? then why the distinction?
I just did this last month using an Aisin aftermarket (same as OEM with Toyota shaved) water pump. I paid around $94 with shipping from Rock Auto but then saw the OEM Toyota on eBay 2 weeks later for the around $92. I should have bought Aisin from Amazon for the same price plus tax with Prime and free return. Anyway...its back up to ~$140 to $160 right now for OEM Toyota on eBay. Prices for these item seem to fluctuate on eBay all the time. I bought OEM hose and Tstat on eBay and the price for Tstat dropped over $10 to $23 while my order was in shipping...the seller refunded the difference.
See links below for the parts you need. Mostly all OEM.
Only one I recommend aftermarket is the Bando or Mitsobushi belt. These go for $13 all day but OEM is $60 for same thing.
OEM Water Pump (was ~$92 in April 2018 but back up to $160)
https://www.ebay.com/itm/FACTORY-OEM-TOYOTA-LEXUS-IS-GS-RC-NEW-ENGINE-WATER-PUMP-16100
OEM Lower Hose (~$30, 2018)
https://www.ebay.com/itm/FACTORY-OEM-LEXUS-06-12-IS250-IS350-NEW-LOWER-RADIATOR-HOSE
OEM Upper Hose (~$20, 2018, don't make my mistake with aftermarket which requires cutting to length)
https://www.ebay.com/itm/FACTORY-OEM-LEXUS-06-12-IS250-IS350-NEW-UPPER-RADIATOR-HOSE
Bando Belt (~$13, definately do aftermarket if its Bando or Mitsobushi, which are OEM suppliers. OEM belt is $60))
https://www.ebay.com/itm/Serpentine-Belt-Rib-Ace-Precision-Engineered-V-Ribbed-Belt-BANDO-7PK1550
OEM Thermostat ($25, 2018)
https://www.ebay.com/itm/FACTORY-OEM-TOYOTA-LEXUS-WATER-INLET-SUB-ASSY-WITH-THERMOSTAT-16031-31020
OEM Toyota Extra Long Life Coolant (~$47 for two pack, 2018...you can get this locally at dealer, have them price match eBay, most will do it)
https://www.ebay.com/itm/NEW-2-Gallon-Toyota-Super-Long-Life-Antifreeze-Coolant
The following 3 users liked this post by sinister2c:
https://youtu.be/0uImhl8XzB0
wow your car is sweet.
I probably could have have gone without replacing belt or the hoses but for the price, had to do it while I was in there. If any of that failed before next pump replacement, I would have been more mad about spending another $50 on radiator fluid to change.
bryceis250 (05-31-18)
thanks alot guys. i just wanted to have them on hand if i pull them an they are loose. see, i had an accident and the whole front of the car is off. i figured id be plain stupid to not do this now. the hoses look pretty solid, so im not going to replace them. cant thank you enough for your time. but i do have one more question. on the belts, i have to admit im weary of buying that 13 dollar belt. your saying this company charging 13 is the same company making the OEM ones?
Yes. Bando and Mitsuboshi make all the OEM belts for Toyota. This belt is cheap because almost all the Toyota V6 engines use the same belt. I can almost guarantee that the OEM belt from Toyota that goes for $50 will be one of those to brands and probably the same reboxed belt.
99367-C1550 was the OEM part number. It has since been replaced by 99367-K1550. I remember paying $36 about 8 months ago for the Lexus part on Amazon from LPW Parts. There's a listing on Amazon for the Toyota belt (under the 99367-C1550 part number) that costs $40 and it will fit the IS250/350, while the Lexus belt (with the same C/K part #) is about $60 now for some reason. I imagine the prices went up once C was replaced with K, which probably coincides around the time I bought the C part.
If the Toyota part somehow doesn't fit, which I know it should, it's shipped/sold from Amazon so it's an easy return.
bryceis250 (05-23-18)
i love that pearl , man thats sweet
