Sc400 loss of power, runs rich, loud
Old 05-15-18, 08:21 PM
Braaap1uz
Braaap1uz's Avatar
Default Sc400 loss of power, runs rich, loud
I recently bought a 92 sc400 and it ran perfect for about 2 weeks before randomly messing up one morning when I tried to start it.
Issues:
Before any major issues, the car randomly stalled at stop lights every once in a while.
Barely wanted to start, cranked and cranked until just barely starting up.
Next, I tried driving down my street and it bogs down when I floor it, but will get up to speed when I slowly accelerate. Drove it around fine, up to 50 mph but like a slug. In first gear it drives pretty nicely, but as soon as I put it in second gear it won’t go above 1k rpm.
So far I’ve tried replacing:
Fuel pump ecu
spark plugs
ignition coils
sent ECU to get fixed.
Right now I’m investigating the camshaft/ crankshaft position sensors. The info I’ve found on symptoms of bad ones matches pretty closely to what issues I have. But I’m not sure whether my issue is cam or crank position sensor.
I’ve also checked the throttle body, it’s pretty clean and snaps perfect, opens all the way when floored in accessory mode. After sitting in my garage a few weeks,and turned on a few times it also started misfiring pretty bad when revved up. Sounds like 2 step.
Any help with this would be greatly appreciated
Old 08-16-18, 05:07 PM
Braaap1uz
Braaap1uz's Avatar
Bump?
bump?
Old 08-16-18, 07:12 PM
FatBrian81
FatBrian81's Avatar
Another user recently posted about a similar issue and found his o2 sensors were bad, it might be worth a shot to check them out.
Old 08-17-18, 07:06 AM
BlackIRON
BlackIRON's Avatar
Any engine codes?
Old 08-18-18, 04:28 PM
xCWolf
xCWolf's Avatar
I recently posted this, my o2 sensors were black. still haven't replaced them
Old 08-20-18, 10:04 PM
java300hp
java300hp's Avatar
Issues:
Fuel pump ecu
spark plugs
ignition coils
Wait for ecm.. then run the car and pull codes..
Old 08-22-18, 09:23 AM
Impressed
Impressed's Avatar
Mine was disintegrated distributor rotor and cap.
Old 08-26-18, 11:02 AM
xCWolf
xCWolf's Avatar
Wouldn't that cause it to not start at all?
Old 08-26-18, 11:38 AM
Impressed
Impressed's Avatar
Mine missed, ran but only on 4 cylinders. Way do in on power. Two distributors,two coils.
Old 08-26-18, 11:39 AM
xCWolf
xCWolf's Avatar
Yeah not the same problem as mine than, occasionally it runs fine and it's not misfiring.
Old 08-26-18, 01:42 PM
Impressed
Impressed's Avatar
I'm new to them 2. Frustrating. Try pulling codes. Obd1 though, oriely may be able to help. Let me know, curious
Old 08-26-18, 01:45 PM
xCWolf
xCWolf's Avatar
No codes. Never threw any.
Old 12-09-18, 02:42 PM
DaBeast421
DaBeast421's Avatar
Default Mine as well
My 92 sc400 is doing the same...if you've had any headway on this matter I could definitely use the remedy.
thank you for sharing your troubles
Old 12-09-18, 08:23 PM
Braaap1uz
Braaap1uz's Avatar
I’ve found that it’s the ECU that’s messed up. I even had it rebuilt but it’s just completely dead at this point. I’m looking at working used ones
Old 12-13-18, 12:53 AM
DaBeast421
DaBeast421's Avatar
Ok...thanks I'll give it a shot...if it a cure I'll let you know
Sc4kid
06-23-17 05:52 AM
9Dragnfly2
01-11-15 05:32 PM
Courn1
02-28-14 08:47 AM
LnlyKPetty
05-26-13 12:36 PM
SpecialK47
02-15-12 07:16 AM
Quick Reply: Sc400 loss of power, runs rich, loud
